Results 1 to 8 of 8
    Apr 06 2007
    Jacksonville, FL
    ATP GT2X kit for 1.8t A4 B5, ECU, Injectors, TIP & MBC
    For sale: ATP GT2X Turbo "kit" for A4 or B5 (Passat) 1.8T. Kit includes the GT2X turbo, ATP/MIKA programmed ECU (8D0 907 557), Green Top Bosch injectors, ATP TIP (Turbo Inlet Pipe)...used for about 9k miles: $1,200
    This setup with ATP CAT Delete pipe, Forge FMIC and HKS CAI made 18lbs of boost with the stock frequency valve. Performance was very good and just what I was looking for; everyday drivable (Zero detonation!) with more performance then the K04 upgrade and the GT2X rocks the K04!!!
    Using a N75 frequency valve the above made 20-21 lbs of boost and turned it into a screamer for what it was. Who ever steals this away from me I will also throw in a new Forge MBC (manual boost controller)...I had plans to install a manual boost controller to increase the boost to 20+ lbs without the spikiness of the N75...the N75 was fun, but it was spikey making the boost come on very hard causing unexpected tire spin!
    Additionally I have a Forge FMIC made for the A4 / B5 Passat, and I strongly suggest you install a good FMIC with any turbo upgrade...$400
    See my other posts for Hella Projector HID lamps, Milltek Exhaust and more.
    Please send email to: [email protected] with inquiries
    Thanks for looking!
    Jack
    Senior Member Three Rings spxxx's Avatar
    Jul 31 2007
    bay area
    Re: ATP GT2X kit for 1.8t A4 B5, ECU, Injectors, TIP & MBC
    price for TIP alone?
    Laser Red 1.8tqm GT2X pc16 --> sold
    REVO + 034 Goodies >>> B6 A4 1.8tqm
    Jun 27 2007
    Montreal
    email sent.
    Registered Member Two Rings kuyagelo's Avatar
    Dec 05 2006
    san diego ca
    passats and a4s are interchangeable ecu's?
    Apr 06 2007
    Jacksonville, FL
    yes, as long as your ecu is a 8D0 907 557 then yes it will work.
    Apr 06 2007
    Jacksonville, FL
    Not parting out at this time...$1,200 for all of this is a deal!
    Jun 27 2007
    Montreal
    pm sent
    Jul 31 2007
    bay area
    if you are willing to part it out let me know i will take the TIP and tuning.
