Results 1 to 17 of 17
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Wheel spacer question
    Just got done doing my b5s4 brake upgrade.... and my 19" rs4 reps wont clear them. Size on the wheels is 19x8 offset is 42. What mm wheel spacers do i need in the front to make them clear. Thanks
    BTW tires are 245/35/19
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Wheel spacer question
    I could be wrong...but I think you need to be around the 35mm offset range to clear.
    My wheels are 35mm offset and I clear them only by like 2 mm
    -Sami-
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    i had some usp reps that were 18x8 et35 and did not clear. all reps are not created equal. the spoke angle has a lot to do with it. i ended up getting new reps at 18x8.5 et30 and have about 4 mm clearance if not 5mm.
    Nov 04 2007
    Minnesota
    so would 10mm spacers work, or thicker..... and also what should i do in the rear like 15mm, or will that rub?
    Current:
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    As mentioned, not all reps have same spoke angle. My version 1 VMR reps are et42, and I run 8mm spacers to clear 332 Stoptechs, which are similar to B5 S4 caliper size.
    My 2004.5 APR Stage 3+ is SOLD
    Nov 04 2007
    Minnesota
    would 10mm spacers make the wheel stick out further than the fender
    Current:
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    an et 35 is pretty much flush with the fender (7.5 or 8 inch wide) depending on the width of the wheel
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by rxrep View Post
    Correct, not all reps have same spoke design. Our V.2 reps clear the B5S4 calipers no problem. 8.5" wide with a +38 offset.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by vdubstreets View Post
    7.5 or 8" wide wheel with ET35 is not "pretty much flush with the fender". However a 8.5" wide ET35 wheel is flush with the fender.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Offset is secondary. OEM 17x7.5 ET45 wheels easily clear the B5 S4 brake setup. The spoke/wheel design is crucial.
    Appearance: OEM+
    Nov 04 2007
    Minnesota
    Quote Originally Posted by Tgr_Clw View Post
    Yeah, they cleard no problem
    Current:
    Nov 04 2007
    Minnesota
    So can i run 10mm spacers in the front bringing it to a +32 offset???? will that stick out to the fender or past the fender? and also can i run a 15mm spacer bringing the offset to a +27. or is that too big of a spacer?
    Need to pick some up soon
    Current:
    Nov 04 2007
    Minnesota
    Bump i realy need to buy them this week
    Current:
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by gotboost View Post
    +32 could be a possibility with some fender modifications, and no way +27 would work on a 245.
    -Charles@VMRWheels
    www.vmrwheels.com
    Nov 04 2007
    Minnesota
    So would 8mm spacers in the front and 10mm spacers in the rear work fine then? And also what brand spacers should i get
    Current:
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    I'm running 8mm spacers up front and no spacers on the rear with my ADR M-classics. The ET on the ADR's are 35. The 8mm are the lowest I can go for the to clear my brakes. I'm also running 245-35-19 Pirelli's on 19X8 rims. I'll eventually go down to 235 when the current ones start to bald.
    I went with H&R spacers w/o the lip.
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Jun 14 2005
    Anaheim, CA
    I dont have any recommendations to the size of a spacer but i do recommend you use high quality hub centric spacer such as H&R or Rouge Engineering.
    -Charles@VMRWheels
    www.vmrwheels.com
