Results 1 to 14 of 14
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Installed Snub Mount
    Just got done installing the APR snub mount. Happy with the results. Little vibration around 800-1000 RPM's, but no biggie. Shifting is cleaner and you feel the motor more.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Installed Snub Mount
    Nice work.. I had the same thing but it is almost completely gone after about 1K miles...
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by pondside36 View Post
    That's good to know!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Was the original cracked?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I have a new tip, for installing any mount on the car too almost reduce vibrations completely!
    As Lee (rxrep) has stated, let the car idle (no throttle blips) for like 30 seconds and then shut the car off and tighten. I have found this method to be half true. Letting the car idle will let the mounts vibrate themselves into postion, but then when turning the car off, it can unseat them. Instead, let the car idle for like 30 seconds, and then tighten the mounts down with the car still on!
    -Sami-
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by aaaudiprotein View Post
    It was starting to fall apart. I can tell a difference already.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    A4 B6 USP
    Orlando, FL
    [QUOTE=absolutegtr;2649368]I have a new tip, for installing any mount on the car too almost reduce vibrations completely!
    Thanks for the info. Have you tried it? It makes sense though. When I installed it today I shut it off and then tightened the bolts. I might try and do it the way you suggested.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    Congrats! I did mine and there's definitely a difference.
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Vossen HF'5's, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by Firefighter637 View Post
    I see, cause i didnt feel that much of a difference.
    Feb 19 2007
    Charleston, SC
    Of course I have tried it.
    About 3 months ago I did my motor mounts (and in doing so i had to remove my snub mount). Anyways, after that it had always vibrated, (because i shut the car off), but just last week, I found my snub mount to be cracked in half, so I duct taped it together (temporarily) and it was a BITCH to squeeze it into its bracket, so I though that it would vibrate a hell of alot more. But while I was under the car taking it out, I though how turning off the car would just unseat the mount alltogether. So I just let it idle for like a minute and then tightened it down and no there a LITERALLY ZERO vibrations! I used to be able to feel it in my butt and back and now it is as smooth as ever!
    -Sami-
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    FedEx says my Apikol will be here Thursday. My stock one is apparently crumbling.
    FireF - did you use ramps? I don't know the orientation of the parts yet, so I was wondering if the fact that the car will be on an incline will affect the settling motion that the idle is supposed to cause.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Quote Originally Posted by kwimberly View Post
    I used car ramps like the APR site suggested. Don't think it would make a big difference if you used either a jack or ramps, but the ramps are safer!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 03 2008
    Orlando
    old guy sent me a link where he suggests putting the front of the car on ramps such that the car is level - like pulling to the end of a driveway so that the back would be level when pulling onto the ramps.
    Looking forward to installing this week...
    Kevin W.
    Veteran Member Four Rings VAG_4ever's Avatar
    May 27 2008
    IL
    congrats! I just did the same thing on my car a couple of days ago! easy install and love the results as well.
    -Meredith
