Results 1 to 11 of 11
    Nov 04 2006
    05 S4
    LI, NY
    spare tire question
    hey....when I purchase some aftermarket wheels....what happens to the spare. I mean...if I go with 19's right. Standard 235/35/19 and I get a flat....is it safe to use the OEM 18? Only asking cause I know about the quattro and the wheels have to be withing a certain percentage of each other and all....can I ride around with the OEM in the back without worrying that i'll destroy my rear or diff if used.
    asking because most used sets of wheels are just 4....and I've never seen this asked before. thanks,.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: spare tire question
    You should go with 245/35/19 for better grippy =)
    Yes it is fine because the profile of the tire becomes lower, therefore the rolling diameter is still equal! what kind of wheels are you looking at?
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    You can do that or just by 5 wheels like I did.
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    Active Member Two Rings z0lt3c's Avatar
    Jun 16 2008
    Hunterdon County, NJ
    Quote Originally Posted by likewater View Post
    Does a 19" wheel fit in the OEM B6 S5 spare tire well?
    Dec 05 2006
    So. Cal.
    Don't waste the money. You'll probably never get a flat.
    Nov 04 2006
    05 S4
    LI, NY
    you just jinxed me ed....lol
    and i actually just picked up a set of BBS CH wheels used with 245/35/19 potenza re050s
    should arrive late this week.
    Dec 05 2006
    So. Cal.
    Nice. Not the jinxing you but the CH's. Gotta love that wheel! Pole position's gonna stick like glue.
    Dec 06 2006
    those tires will be fine (rolling diameter). I heard taht 19s wont fit in the spare-wheel well though... (which nullifies the possibility of buying 5 wheels) although I dont know if that is true. I guess if i get a flat (knock on wood) driving wont be the problem but just throw the flat tire in the trunk instead of in the proper storage thing (under trunk)
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    1. yes you can probably fit the 19"tire into the back, but i would run a stocker
    2. Running 18" even with the same thickness tire is fine, since youll be changing it anyway soon
    3. dont count your chickens, manhole came out of nowhere about two weeks ago and blew out both right side tires, luckily I had a spare and the rear was just a bad bubble so I nursed it home.
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Dec 05 2006
    So. Cal.
    Here's an idea! Get an RS4 setup for your trunk. We don't have spares in our trunks, only a compressor. Check it out. It might be for you.
    Sep 18 2006
    So Cal
    Quote Originally Posted by z0lt3c View Post
    B6 S5? I think you meant S4 - if so yes it fits.
