Originally Posted by
tgiblin
Thank you, I have searched and searched with no luck.
Questions:
Do I need to remove the Heat Shields from the car?
If I ruin a heat shield do I have to get a new one or can I run the car without it?
What is this 17mm wrench everyone is talking about? I have a 17mm wrench but people talk about an extended one?
Yes, you need to remove the shields. Some put them back on, others do not. I did and wish I hadn't, could've shaved an hour or two off removal/installation.
You're gonna need several wrenches and extensions and various other tools.
From the audiworld write up:
http://www.audiworld.com/tech/eng43.shtml
3/8 Drive Socket Wrench
Long Extension (I used a 24" extension)
2 Medium (6 inch) extensions
7 mm Deep Socket
8 mm Deep Socket
13 mm Standard Socket
5 mm Allen/Hex Socket
6 mm Allen/Hex Socket
Universal Swivel Joint (may come in handy)
1/4 Drive Socket Wrench (used mainly for leverage advantage in some situations)
1/4 - 3/8 adapter socket or same attachments as 3/8 Drive above
O2 Sensor Socket *very important* (Try to get a deep O2 sensor socket, it will
make things easier...will likely be a 3/8 drive)
Wrenches
10 mm standard wrench
13 mm standard wrench
17 mm standard wrench
17 mm `extended' wrench (explained below)
22 mm standard wrench
Screwdrivers + misc.
Philips-head Screwdriver
Flathead Screwdriver
Large Pliers (non needle-nose)
Extendable magnetic wand (trust me it WILL save you at least once)
Duct Tape
Zip Ties
