Results 1 to 4 of 4
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Question Anyone ever use LED Flashers / Equalizers?
    http://superlumination.com/equalizers.htm
    http://superbrightleds.com/flashers.htm / http://superbrightleds.com/tail-brake-turn.html (near the bottom of the page)
    They are supposed to make your LEDs flash at a normal rate and are supposed to be better than resistors (and cost a considerable amount more.)
    I'm not even sure where or how to install them.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Jul 10 2007
    trunk
    Re: Anyone ever use LED Flashers / Equalizers?
    Pride sunday bump (for some of you).
    Stage 0 minus - .5
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    The obvious answer would be to ask the sellers, but typically the original flasher unit (usually near the fuse panel, but I can't say for sure for Audis) is a bimetal-strip heater type flasher unit. It gets hot because of the load of the regular incandescent bulbs, and the heat makes it shut off, then it cools and reconnects, etc, and hence flashes. But LED's take much less current so the stock flashers don't heat up enough to work. Some people add resistors to create a fake load, but that's purposely burning power and totally defeats one of the major benefits of LED's. The better option is electronic flashers, which I assume these are. It should be a matter of pulling out your flashers, and replacing them with these, or wiring these into the flasher circuit.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Jul 10 2007
    trunk
    Thanks for the explanation; now I just have to find out where it is and what type I need for replacement.
    Stage 0 minus - .5
