Results 1 to 13 of 13
    Active Member Two Rings Oscar32's Avatar
    Jul 24 2007
    B6- 04 A4 1.8T Quattro
    609, NJ
    B6 Clutch HELP!!!
    Hello all,
    I'm looking for a repair shop in central jersey that can help me with my 2004 Audi Quattro A4 1.8T. i think i may need a new clutch and not sure where i can get this fixed in my area with out gping broke.
    Please help!!! i need my car .
    Also if anyone has any suggestions on any aftermarket clutch kits that i can purchase that might be a good upgrade compared to stock...
    i can get the parts, so i really need is someone to do labor.
    Peace!,
    Oscar
    Alianza
    609,NJ
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: B6 Clutch HELP!!!
    If you are anywhere near Cherry Hill (which I am assuming given your 609 area code) give AutoSpeed Performance a call. They specialize in Audi and VWs.
    http://www.autospeed.us
    -Doug
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Doug is probably right, he usually is.
    But just for a comparison so you know how right he is give these folks a call.
    clicky click
    If I may say so, the OEM RS4 clutch made by LUK ought to be more than enough for the car and will retain stock-like driveability. And they're a good value, being able to find one online though a forum (E.G. AZ, AW, AG, AF, etc) is also an option, as well as eBay. Not to mention the VR6 clutch or even the OEM A4 clutch, which my mechanic assured me is good to stg. III.
    Otherwise many people seem to like the Southbend clutches, with differing tastes depending on mod plans and engagement point. Try searching Southbend OFE, HD and so on. And there's a recent thread I replied to saying the same thing about OEM clutches titled something about how much power a clutch can take where Old Guy gives his advice.
    GL!
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Jul 24 2007
    609, NJ
    Thanks alot guys!!!
    Peace!,
    Oscar
    Alianza
    609,NJ
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    How much TQ can the Rs4 clutch handle? and what materials is it made of
    Jun 28 2007
    Edmonton, AB
    Quote Originally Posted by audipotential View Post
    Organic, IIRC, and same power as an RS4 plus an engineered safety margin. The US spec 2.7t Allroad uses the same clutch plate too.
    Apr 12 2007
    Milwaukee
    i don't think the 1.8t FW will take a 240mm V6 clutch setup
    Jun 30 2007
    Raleigh, NC
    ^it wont... i looked into that already. lol
    and FWIW - the s4, rs4, and allroad (anything with a 2.7TT) all share the same clutch and DMFW... the difference is in the pressure plate. (the rs4 being stiffer)
    also, i dont know why your mechanic told you that an OEM A4 clutch could handle a stage 3 setup... but my AWE stage 3 couldn't handle my stage 3 setup... and it was DEFINITELY a better clutch than the stocker. *that being said, the AWE is a great clutch kit - and it could take the power from a roll... but not on a hard launch.*
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 25 2004
    Earth
    You will need a custom flywheel to run the 240m clutchs.
    ECS makes one in both steel and aluminum:
    http://forums.audiworld.com/a4gen2/msgs/975756.phtml
    as does Spec:
    Buncha motorcycles
    Memphis, TN
    how would aluminum hold up on a feramic clutch disc? would it clog the surface of the disc if slipped?
    APR Stage 2/AWE Intake
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Papachristou View Post
    Most all aluminum flywheels now use a steel insert ring. Most of the flywheels that dont have the ring are Billet Steel. Aluminum wont hold up to the heat the friction from the disk will produce and would warp very easy.
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    the aluminum flywheel has a replaceable steel insert for the clutch surface. but that begs the question in my mind would it be more prone to chatter or warping. over time and harsh use?
    I like spec's steel flywheel it looks like one solid piece that could be reused a few times.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Jul 07 2004
    socal
    Quote Originally Posted by durfA4 View Post
    Well the heat can still travel thru the insert and chatter increases as the flywheel gets lighter/less dense. I had way more chatter with my 12 lbs billet aluminum flywheel then I do with the 16 lbs billet steel. The Spec 16 lbs flywheel seems to be the flywheel most people buy now since it is a bit lighter then stock but not so light that it changes how the car needs to be driven but still makes the engine more responsive.
