Results 1 to 11 of 11
Thread: LED DRL's!!
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    LED DRL's!!
    just got my led drl's in from some company who ships out of china, they were extra cheap, about 10$ with shipping
    they're brighter than the pictures show. i've got some 25 watt 10 ohm resistors i got from fry's for a buck a piece that i need to wire up to get rid of the bulb out warning. they say flame proof, but have no heatsink. should i try to find one to be safe? or just mount them where they wont touch anything that'll melt?
    also does any body know what wires i have to tap on the big harness for the lights? i know the ones inside are yellow and brown. and i do have a bently manual that covers 02 - 06 a4s
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Senior Member Two Rings dj_dub's Avatar
    Mar 07 2008
    2010 BMW E90 M3, 2001 Mercedes Benz ML430, 2010 VW Tiguan SEL
    Re: LED DRL's!!
    looks good bro! ...i gotta see that in person!
    2010 BMW E90 M3, 6MT - Space Gray / Fox Red & 2006 BMW E46 M3 Vert, SMG - TiAg / Imola Red
    2008 Audi B7 A4 2.0T Quattro, 6MT - Phantom Black Pearl (sold) | 2000 VW MkIV Golf 1.8T, 5MT - Uni Black (totaled)
    NoFuknJoke | Photographer
    I1I1III
    Mar 26 2008
    Re: LED DRL's!!
    yeah man, hopefully i'll see you around union city. i'm staying over off of mission in uc
    16MAR09DSWHTAW
    Mar 07 2008
    Re: LED DRL's!!
    oh tight! ...you're pretty close to me then. i'm off of decoto and alvarado niles. unfortunatly, i'll only be living in union city till mid july because i got a new place in milpitas. hopefully i see you around before then dude!
    I1I1III
    Mar 26 2008
    Re: LED DRL's!!
    damn it. i guess i got the wrong resistors, does anybody have led drls with the right resistor that works? 10 ohm 25 watt didnt do it.
    16MAR09DSWHTAW
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: LED DRL's!!
    cool
    Mar 26 2008
    Re: LED DRL's!!
    thanks i got tired of the halogen drl's. just dont go with the flow of the rest of the lights, next mod is xeon match bulbs from hoen. to completely the xenon look
    16MAR09DSWHTAW
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Re: LED DRL's!!
    Load equalizers is what you need for LED DRL's. They resolve the blub out warning but run really hot. I've tried them out and it works but I didn't want to hide them inside the housing as it could melt whatever it touches.
    http://autolumination.com/equalizers.htm
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Mar 26 2008
    Re: LED DRL's!!
    Quote Originally Posted by DoThisMyWay View Post
    they just look like the resistors i have, but with a wiring harness and heat sink. do you know what the wattage and ohms of the one you go? are you still using them/have them? i'd rather do my resistor route, because frys has them for a buck a pop.
    16MAR09DSWHTAW
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Re: LED DRL's!!
    I have either 3 or 6 OHM/50 Watt load eq. I still have them but I'm not using them. I tried using resistors but at those specs of the load eq, the resisor size is pretty big.
    Current:
    Previous:
    Mar 26 2008
    Re: LED DRL's!!
    i think i'll try those, i have my resistors set up where they wont touch anything. they do get hot and are pretty big, thanks man
    16MAR09DSWHTAW
