Results 1 to 9 of 9
    May 22 2008
    Santa Maria
    Yakima Roof Rack Question...
    Just installed my Yakima roof rack on the factory rails last night. I am a bit concerned about the clamps though. From the outside they wrap around the factory rail well, but the inside bracket only touches the very top inside edge of the factory rail. Is this normal? I am a bit worried about the rail getting dented in from the yakima clamps when they are snugged down....
    Anyone know the answer to this? Also, it seems you have to open the clamps way up to get them off the rail, causing the crossbars to also be loose. I don't think I did anything wrong, just seeking feedback from those of you who have this rack.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: Yakima Roof Rack Question...
    pics?
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    If you have factory rails, you most likely have the Avant. Which clamps did you get? I believe the right clamps for factory rails are called Yakima Lowrider. Most on the Avant forum also like the Yakima over Thule or Audi rack. Check out this thread: http://www.audizine.com/forum/showthread.php?t=136768
    Oct 31 2006
    San Antonio, TX
    Lowriders are the correct clamps. Post some pictures of it installled and we can take a look. I also have a Yakima rack for our B7 Avant, so I can take and post some pictures of ours installed for you to compare.
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Mar 12 2008
    New York
    I've installed both Thule and Yakima on avants (work at a ski shop). It's pretty hard to mess up and will not dent the rail. They don't need to be gorilla tight either. The only thing you'll want to do is wax under them once a season or so
    May 22 2008
    Santa Maria
    I'm sure they are on right. I have no way of posting pics. can someone post a close up of their yakima rack?
    May 22 2008
    Santa Maria
    anybody?
    May 22 2008
    Santa Maria
    Here are some pictures. Notice the gap at the bottom of the inside bracket:
    May 21 2008
    kind of hard to see with the reflection, but I think it looks good
