Results 1 to 10 of 10
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Rs4 K04 failures...
    couple of questions regarding K04 RS4 Turbos
    - why do these fail so quick ? here in europe we have many RS4's with +75.000km that run fine on stock turbo's, I can understand a turbo fails after 100.000km or 40-50.000km of abuse and + 22psi but I've been reading alot about K04's going in a year or even faster after 5000-10.000km.
    - Are they using crappy material these days for the new k04's or does it have something to do with installation?
    - Is it better to buy 2nd hand RS4 turbo's and have them rebuild with all new stuff inside?
    - Do RS6 Turbos fail as quick as K04's or are these better made?
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Re: Rs4 K04 failures...
    Quote Originally Posted by Audi_S4 View Post
    Now I would suggest you take any post with a grain of salt because failure issues can stem from alot of different issues but the most problematic problem is poor installation. Usually if K04's fail its because there is a leak somewhere on the turbo or inlet lines and that basically doesnt lube the turbo enough and ends up seezing/broken. (but those failures shouldnt happen if the install has been done correctly and safely)
    They have been more and more common these days for some reason.. A few stories here and there. But K04's are very reliable and should be taken into consideration if your thinking of a nice reliable setup. Buying them brand new allows you to have a little less worries about whether or not they are going to die but buying them second hand and having them rebuilt can be a more cost effective way to make a kit. So its a more cost vs. (worry factor) for me, and you should think whats best for you.
    Alot of people are starting to run GT setups. Either from companies well known like AutoSpeed or running custom kits from board members like GenerationJDM. Gen's kit are awesome and for the price to hp gain its an incredible deal without a doubt. If your thinking this might be an idea just contact him and I am sure he will give you prices on kits and you can go from there. GT turbos should be alot more reliable than K04's since you can get them in dual ball bearing instead of thrust bearing or journal bearing. The GT turbos themselves are also much more cheap than getting the Borg Warner KKK versions. Plus having the wastegates external you can diagnosis problems a little bit better and replace an issue more effectively then just replacing turbos with integrated wastegates together.
    If you have anymore questions I am sure someone will chime in more experienced and let you know.
    Cheers
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Bottom line, the rs4 turbos are 40+ year old technology and was never designed to be abused to the extent that there being abused at.. These turbos are being pushed way past there intended design, ya you will have some that say they've been taking a pounding for years, but that sure is a lot of money to hope they work out... I here quality control is part to blame, but who knows...
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    I think the real problem is that out of the thousands of people that use k04's, your only going to hear about the ones that blow on the forums and are more than likely the people that had them installed wrong/cold boosted the crap out of them/didn't use sythetic oil etc...
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Mar 14 2007
    michigan
    And theres all the ones that don't belong to any forums that popped turbos you will never hear about either...
    Feb 20 2008
    belgium
    Quote Originally Posted by generationjdm View Post
    and Theres All The Ones That Don't Belong To Any Forums That Popped Turbos You Will Never Hear About Either...
    Mar 20 2008
    Italy
    OT Are you ready with your kits, jdm?? /OT
    Cheers
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    ahem ..... correct install, fully synthetic oil since the car was bought and before that, always let the oil and coolant heat before boosting and always let them cool and they died in less than a yr .. probably like 600 miles soo gen gt kit here i come hehe :)
    ohh and stage 3 minus on 15lbs of boost only lol
    cheers
    ---daniel
    Aug 10 2007
    Quote Originally Posted by alias747 View Post
    There is always going to be a few bad oranges in any batch. There is risk in any modification.. But for the price there are alot of options when doing a turbo upgrade.
    Feb 20 2008
    belgium
    yeah but it's fucked there aren't any GT turbos you can put on stock manifolds and downpipes , then everyone would go GT.
    I am not aiming at BIG power, I have 270 @ wheels right now and I like it but after 3th gear it does not pull enough anymore... , with +- 320-340 whp I would be very very satifsfied and it's silly to spend 7k to get there...
    I have AWE downpipes / new larger SMIC's and a new passnger side K04RS4 lying in the shelf and allready have a dual cat back. so a RS4 clutch,injectors and remap and I would be settled but it's a hell of a job to get the suckers in and it will cost me like 1500€ for the work only! and if they blow after 5-10.000km I'll kill the S with a chainsaw! ! !
    are they stronger with RS6 chra?
