Results 1 to 7 of 7
Thread: Tire size
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Tire size
    ok, so i'm getting wheels in this week for my A6, and its lowered so i was worried about rubbing, the wheels are 18x9 all around, and what do you think i should use? with 18x9 235-40-18 or 225-40-18??? thanks guys.
    2004 Audi A6 2.7T
    Deactivated Three Rings
    Apr 11 2008
    Re: Tire size
    18 would USUALLY fit okay with a 225/40. I'm getting a new set soon (18 x 8.5) and tirerack recommended 235/40/18. So I would only imagine that a 18 x 9 should go at least 235. I think the 225 would be a stretch for a 9" wide wheel.
    Mar 30 2008
    Pittsburgh
    Re: Tire size
    well its is kind of a stretch, and i want a small stretch, but you think 225 on 9" wide would be ok without rubbing? thanks
    2004 Audi A6 2.7T
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Tire size
    235/40-18 and 245/40-18 are the only sizes we recommend. The 225 would have to be XL to carry enough load to used safely.
    Mar 30 2008
    Pittsburgh
    Re: Tire size
    well they are XL, but do you guys think 235 will rub?
    2004 Audi A6 2.7T
    Oct 06 2006
    South Bend, IN
    Re: Tire size
    If you are lowered more than 1.5" then the 235 may rub if the spring is fully compressed. Maybe someone has some firsthand experience ?
    Mar 30 2008
    Pittsburgh
    Re: Tire size
    well i have the eibachs, and its 1.4 in the front and 1.2 in the back, so i should be ok?
    2004 Audi A6 2.7T
