Results 1 to 24 of 24
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Stock brakes stuck to floor after emergency stop?
    The other night I had the need to stop, very quickly, so I slam on the brakes. It stopped nice and short, but the brake pedal stuck to the floor for a few seconds before slowly coming back up and letting me drive off.
    Is this normal? If so, how the hell do you disable whatever causes it? I'm not opposed to completely disabling ABS (never liked it anyway).
    If its not normal, what could have caused it to do that? It has been braking normally since then, pads and rotors are fairly recent. If it hadn't stopped as quickly as it did, I'd be guessing blown seal on the master cylinder, but it didn't let go, and it's behaving now.
    Any thoughts?
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Stock brakes stuck to floor after emergency stop?
    What you experienced is normal. Your car is equipped with "panic assist" brakes. Under certain braking conditions the ABS system determines that you are braking under maximum force and the ABS brake pump will completely lock down the brakes. You probably felt the pedal pull down on its own beyond the force you were already applying to the pedal when this occurred. I would not recommend attempting to disable this ABS function. It rarely occurs and when it does it can save your ass. In the 95K miles I put on my A4 it only happened once and I'm sure glad it did. The typical driver (yea I know, we are all better than the typical driver ) even in a panic stop will not apply the full force that the brake system is capable of handling. The "panic assist" can be the difference of stopping short or rear ending the guy in front of you.
    Oct 01 2007
    Too small
    N/A
    Thanks for clearing it up for me old guy. I'd still like to disable it though. More than once I've had to slam on the brakes, only to have to get on the gas again to avoid something coming up behind me (saved the ass end of one of my MG's on one occasion) or something about to t-bone me (saved my own ass when a police chase blew through a red light). My first reaction the other night was to get on the gas to give the minivan behind me some room to stop, as I was already clear of the obstacle in front of me (asshole in a mustang).
    I do, like most of us, assume myself to be "above average" in driving skill, and I know that electronically assisted braking is generally going to stop you faster, even if you drive race cars for a living. That part isn't a question of skill, but reaction time and feedback, both of which the computer outranks we humble meatbags in.
    But on the other hand, I grew up without all this ABS, ESP, etc... and find the lack of predictability to be almost as dangerous as whatever it is they're designed to help you avoid.
    Reading through the datasheet for this year 1.8TQM, it seems in the way of electronic safety measures that affect driving characteristics I have ESP, ABS, Brake Assist (the thing that got me), EBD, EDL, and ASR.
    ESP - want it gone
    ABS - wouldn't mind keeping it if the BA can be disabled separately
    BA - want it gone
    EBD - can stay, but would just as soon use a proper proportioning valve
    EDL - no idea what it is
    ASR - no idea what it is
    Any idea how much of that can be addressed via vag-com?
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Jun 30 2007
    Raleigh, NC
    if you get a MAF-less tune and the BT to go with it, it'll permanently disable your ESP
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Oct 01 2007
    Too small
    N/A
    As much fun as that sounds, I don't plan on going any further than K04. This is going to remain a daily driver, and I much prefer low end grunt to high-RPM screaming.
    What are the advantages to a MAF-less tune?
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Jun 30 2007
    Raleigh, NC
    oh ive got plenty of low end grunt. it doesn't take long to hit the higher rpms either... it's a very balanced kind of power.
    the main reason for going mafless i guess would be to get one more obstruction out of the air path. it also greatly simplifies things. may have something to do with the actual tuning or the way the car reacts to a WOT run, but i never had my BT setup with the MAF - so i couldn't tell you if it's any faster now or not.
    The Awesome™
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    To the OP:
    What do all those acronyms stand for? (ABS, and ESP are obvious...but the rest?)
    -Sami-
    Dec 28 2006
    Western Maryland
    To the OP:
    ESP - Electronic Stability Program
    ABS - Antilock Braking System
    BA - Brake Assist (Panic assist as discussed above)
    EBD - Electronic Brake Distribution
    EDL - Electronic Differential Lock
    ASR - Anti Slip Regulation
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    All our cars have all of that?
    I'm 02 1.8T Avant
    Thanks.
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    Oct 01 2007
    Too small
    N/A
    Grab the .pdf for yours from:
    http://www.audiworld.com/model/a4/content.shtml
    It should be about the same as mine, except with some avant specific goodies thrown in there, so I'd say yes, all of our cars likely have that list of safety gadgets.
    (actually looking at the link, there doesn't seem to be a datasheet for the `02 Avant, but the sedan from `02 or the `03 Avant should be about the same.)
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Jan 16 2007
    Wetzlar
    all of them work together.
    If you think that you don't need them then you are an.......
    Boston
    Quote Originally Posted by nihil View Post
    Close enough, thanks!
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by a2gtinut View Post
    an...?
    Go ahead and spit it out. It's the internet, where everyone has an opinion. You are obviously itching to tell me/us how your opinion applies here and how you are better informed. How do you know what I, or anyone else "needs"? What makes you the expert?
    Don't be shy, are you an engineer for VAG, or just some random idiot on the internet who feels compelled to stroke those keys every time he sees something he does not agree with on a personal level?
    Edit: I just realized I couldn't possibly have posted this. You see, I had cars without electronic babysitters prior to this Audi, and I died long ago in a car accident for lack of a computer to drive my car for me. In fact, I just checked the list of vehicles that I've owned in my life (20+), and this is the only one to have such accommodations, so it stands to reason I died at some point in my mid teens.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Dec 06 2007
    ^^lol! i think a few of those should come on like the C63 AMG, where if u turn the system to sport mode, it'll turn it off, but if u slam on the brakes it'll turn it back on to save ur ass, and then shut off afterwards!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    could be worse, I once had my accelerator pedal stuck to the floor and the car redlining. I don't know the cause of it, but it never happened again.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Boston
    Quote Originally Posted by WiZZLa View Post
    OH! I had that happen on my old Buick back in the day! The Cruise Control Linkage got stuck and didn't go back when the accelerator released!! Had both feet on the brake and I was standing on it like a Golden Academy Award dude!! Had to finally kill the ignition!
    Good times!
    Dec 06 2007
    ^^that sux!
    -Kirk
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    I would've sort of agreed with the unpredictability of ABS etc since my real driving days did not include them, I did have my ABS disabled temporarily for some time on my (prev) B5 and whereas I liked it at first (especially during my first autocross), I think I was much better off getting used to it being enabled. One panic stop in heavy rain late at night around some 18-wheelers made me realize this.
    Perhaps go autocross your car a bit to learn to predict it and get comfortable with it. You should even prefer it once you get really used to it.
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by B6 Dude View Post
    Your one panic stop where ABS came in handy does not mean that ABS is the most suitable solution for all drivers in all circumstances. For every story about how ABS or an airbag or some safety device "saved someone", there is another that says the complete opposite. Sure, in some situations, it'll bail your ass out, in others it can cause more harm than good. There is no end-all be-all safety device that can protect a vehicles occupants from danger. Some devices work for some drivers in some conditions.
    The best thing you can do to avoid an accident, barring the obvious "avoid driving" option, is to be an alert and aware driver who understands how his or her vehicle will react under any condition he/she is likely to encounter. That will save more asses than any little box with silicon inside it ever could.
    On that note, knowing how your vehicle is -supposed- to react, and then having the car go off and do something else (as my first encounter with ESP went), is dangerous no matter how you look at it. How many accidents have you seen chalked up to "driver lost control"? If you're expecting the car to do one thing, and it does another, you are not in control, you aren't even in a position to regain previously lost control, you're playing the odds that a room full of engineers 'got it right' for your particular event.
    Do I think everyone should run around disabling safety devices? Hell no, there's people out there that can't even check their own oil, much less have taken the time to learn how to drive properly. I do however acknowledge that the layer of abstraction between car and driver provided by such things as ESP/ABS/etc... is not the best solution for everyone, and should be handled on a personal preference basis.
    And as mentioned before, I'm not entirely opposed to keeping ABS enabled for myself, as it does offer more consistent stopping results in slippery conditions. I am however opposed to being stuck in the middle of an intersection with my brakes locked up and no way to unlock them until the car decides it's ready to do so. Very opposed to that in fact.
    I'm not trying to bust your balls man, but I'm a firm believer that technology should enhance an experience, not replace it. If I want to drive a fully computer controlled car, I'll go buy a playstation. Again, this is personal preference for my own situation, not a suggestion as to what is the best route for the masses. I couldn't even pretend to know enough to tell everyone what is best for them. If someone is unsure if they should or should not disable a safety device, the answer is a resounding NO, but if someone knows exactly how they want their vehicle to respond, and it doesn't already do so, I see no problem with altering it to suit that persons desires. This is, after all, a car enthusiasts forum, not knitting with Betty.
    (Sorry for the long post, but saving people from themselves is a big money business, and I'm on the fence as to how much saving people actually need, and how much of it is done for the $$$.)
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I applaud you for a well thought out response. It's nice to see someone on AZ acknowledging both sides of an issue. I definitely agree that as a skilled driver, electronic systems affect how you expect the car to react, but it's all about engineering to the lowest common denominator. Though skilled drivers can control slides and steer their way out of a potential accident, it seems that most cars are designed for people to slam on the brakes when they panic, in which case of the above systems would be helping them.
    Example: When I took a "safe driving" class a few years ago we where basically driving around turns in a huge wet parking lot to simulate loss of traction. The instructor kept getting pissed cuz every time the car would start to oversteer, I would countersteer and get on the gas to straighten out like a rally turn. This was my natural reaction as a comfortable and skilled driver(and avid player of racing and rally sims). All they wanted us to do was firmly get on the brakes at the first sign of the skid. In that situation my knowledge of how cars behave during slides makes the electronic systems dangerous as you stated cuz they constantly try to interupt the slide you are trying to ride out.
    However that only applies to situations where I expect to be sliding. In a daily driving situation, I would prefer to have all the systems active as anything that would cause me to need them would be unexpected in which case my panic reaction would probably be to stop as soon as possible and make sure I'm safe.
    PS: I've also had my break pedal stuck down after a panic stop and almost been hit from behind in the snow cuz my esp came on and killed any acceleration so I'm agree with having the ability to manually control them or use a system like the post whore mentioned for the Benz.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Oct 01 2007
    Too small
    N/A
    Well, it did it again. Some lady pushed a stroller out between two parked cars on the right and I had to get on the brakes quick to keep from running over her larva. It wasn't as hard a brake as last time, but it bottomed out and stuck to the floor again.
    I do not like this behavior, and I want it gone. Does anyone have coding values for the brake controller? Or perhaps a diagram of whatever plumbing is involved in the panic assist braking? I want normal brakes. I don't mind a touch of ABS, though I wish there was a switch to turn it off at times, but this type of behavior from a vehicle is completely unacceptable.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Maybe you should slow down a little? In the 20 years I've been driving, I've never had to push the brakes in any car so hard. My Infiniti M35 had brake assist, I drove that car 120 miles a day to and from work and I never invoked the brake assist or ABS on that car.
    I understand things can come out and surprise you, but if you are a good defensive driver, this shouldn't be happening so often. Where do you live/drive?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by 04QuattroTurbo View Post
    I really wasn't driving like an ass. I'm not saying I don't (I generally save it for wee hours of the morning and away from town/cops), but at that particular point in time I wasn't. I was just keeping up with the flow of traffic, and had a bag of food on the passenger seat I was trying to keep from tipping over. I grabbed the bag as I hit the brakes, so there was no spicy buffalo chicken damage to the interior .
    Oh and missed the spawn as well, she jerked the stroller back as I came to a stop, but wouldn't have hit it had she left it there. She was on her cell phone and not paying attention to where she was rolling her offspring.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by AudiA4Turbo22 View Post
    our cars sorta do that... even if you have esp "off" it's not totally off, and will engage in the event that it feels a total and very sudden loss of traction. I plowed through a corner really hard one time and it kicked in quite unexpectedly. I guess i hadn't really nailed it THAT hard before... point being that it chimed in, did it's thing, then went away. still pretty funny when you can't even force your car into the worst understeer of it's life hahaha. car oversteers now though, which makes for some FUNNNNN 2nd gear turns through yellow lights (late at night with nobody around me.. i usually take up more than just my lane when doing this hahaha)
    and for the record, i did it on purpose - i was actually proving to my friend that a stock a4 corners worse than his stock civic on 5 inch wide 14's LOL
    The Awesome™
