Results 1 to 7 of 7
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Brake bleeding & pedal feel
    Hello all,
    Been boning up on some technical white papers from Stoptech and now have a question seeking an answer.
    If it's likely that bargain brake bleeder kits are going to include air, and the professional grade ones are expensive... do you absolutely have to have another person around to help bleed the brakes manually?
    My rotors are straight up rippled... you can see so from standing without bending over for all but one. Now, I understand it may be an accumulation of brake pad material, but I'm not likely to get my rotors machined any time soon. So I figure that until I swap out my rotors and pads for some new ones, fresh brake fluid will have to do the trick (to increase pedal firmness).
    Suggestions?
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: Brake bleeding & pedal feel
    To increase pedal firmness, you will new a brake flush and stainless steel lines. New fluid will put it back to where is should be if you have bad fluid and air in the lines. SS lines will actually stiffen it up a little.
    Aug 26 2005
    Quote Originally Posted by Tactic12 View Post
    Hello all,
    Suggestions?
    Unless you can open/close the bleeder valves, while at the same time operate the brake pedal, in the required order of pedal down, valve open/close, pedal up, repeat, then you will need a helper. I don't know of any other way to perform manual bleeding otherwise.
    BTW, I recently upgraded the FN3 caliper guides on my stock 1.8T front brakes, using 1/2" shoulder bolts to replace the 12 mm guide pins, and Oilite type sintered bronze bushings to replace the rubber caliper bushings. The improvement in the braking in amazing! The brakes are a lot firmer, the pedal is higher when the pads grab, the feel is a bunch more sensitive/responsive, and the brakes are very noticeable more powerful and effective. The setup is very similar to the Tyrol Sport caliper stiffening bushing kit, but uses standard hardware store sourced components, and cost 75 percent less. I don't feel the need for HP2 calipers or 3.0 size larger front rotors anymore.
    Dec 08 2006
    Jersey
    OPh I forgot to mention, about bleeding with one man and no brake bleed kit, I suggest Speed Bleeders. I have them on my brakes and they work great. It's a bleeder screw with a one-way valve so it lets fluid out when you press down on the brake but does not let air in when you let go. I used the HELP! 12701 on my B6 S4 fronts and B6 A4 rear calipers. They were $10/pair at Pep Boys
    Jun 28 2007
    Edmonton, AB
    Wow, great recommendation John... thanks a million. Yet again.
    I'd go straight to the S/S lines but if I'm to tear the braking system apart, I might as well put new pads on to properly seat them then later add new rotors. So for now, I think I'll follow your protocol graciously outlined above.
    I'm going to write it down, verbatim, and go into Canadian Tire or Home Hardware and get that stuff tonight... then the challenge is finding the time/courage (drinky drinky! lol) to get into it.
    Do you have a TSB or DIY handy?
    Again, thanks... a million. And one!
    Jun 28 2007
    Edmonton, AB
    Quote Originally Posted by akaEsCo01 View Post
    Hmmmm...
    This is an excellent recommendation, however, I just do not trust cheap tools to do such a sensitive task. I will look for/at them though, if I can find them (no Pep Boys here), and see what my intuition tells me.
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Motive power bleeder FTW! Makes bleeding a true one-person job.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
