I'll try to make this sound as simple as possible to better help you help me. Bear in mind I have a 2004 Ultrasport.
About a month ago I was driving at night with the headlights and windshield wipers on. I pulled the windshield wiper stalk toward me to spray fluid, which it did. A few seconds later, I got an indication on my instrument panel alerting me that my fluid was low. Okay, so refill it. Duh. Easy enough, right?
Wrong. I dumped in about a gallon and a half of windshield wiper fluid only to watch it leak out of the bottom of the car. Because of where the fluid was/is coming out underneath the car, I knew that it wasn't the tank that was cracked, so I began thinking a hose had popped off.
Sure enough, I pulled my driver's side headlight out today and dumped some water into the tank while shining a flashlight into the space beneath where the headlamp rests, and I was able to pinpoint the site of the leak. It's a little white (2-5mm diam.) tube that appears to have popped off of some sort of junction feeding the headlight sprayers.
My question is, how can I best get to this part of the car? I am afraid of removing my front bumper. My brother says I'll never get it back on the way it was before it came off. If anyone has a good DIY or any sort of writeup explaining this process, I'd be willing to take a look at it. I want to try removing the front driver's side wheel and fender well to access it, but if any of you know that you cannot reach the area I am describing using this method, please save me the hassle and speak up. Also, if anybody has a schematic of the area I'm describing, I would greatly appreciate that as well. Finally, if anyone has experienced this problem or one similar, I would like to hear what your story is/was and how it was dealt with.
I searched. Thanks!
-TS
