Results 1 to 4 of 4
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Piggy/Gutted Downpipe
    I searched for "piggy, piggies, gutted, etc" and no results
    I have a FWD CVT and I want to order a down pipe, however I believe there is going to be a fitment issue (from what I've seen)
    I'm assuming that I'll see a similar gain from pulling the stock dp and gutting it so it is free-flowing. I would also use the CEL spacers on the o2 sensors to prevent a CEL.
    Anyone have input on this?
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: Piggy/Gutted Downpipe
    Not sure if spacer will work though, but there is a test pipe you can get. Power wise there are some that reported that it works while there is one data taken from someone that doesnt work.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Get a test pipe, go get reflashed with APR to remove CEL
    -Kris
    Apr 02 2008
    LA
    Can anyone link me to the dp that works with the fwd cvt? thanks!
