Results 1 to 12 of 12
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    DSMIC install...HELP!
    I've gotten through most of the install of the factory DSMIC kit (the one from the Euro S-Line A4). Everything was OK up until the point where I needed to reconnect the vacuum line to the DV. Its like 12 inches too short!
    Is there something I'm missing here? I've double and triple checked and everything is plumbed the way its supposed to, but I still don't have enough hose to reconnect the DV.
    Little help please!!!
    boy412
    Jul 15 2007
    Mount Rainier, MD
    Re: DSMIC install...HELP!
    Oh...and what would happen if I drove a short distance with no vacuum line attached to my DV?
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    if the vacuum line isnt hooked up to the diverter valve, the diaphram inside wont open the valve to get rid of the charge air, and if the diverter valve is not working that will lead to compressor surge.
    If all you need is 12 inches if line...just go to the store and buy like a foot or so!
    -Sami-
    Senior Member Three Rings topcat's Avatar
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    get longer vac. line. I had to do the same.
    Jul 15 2007
    Mount Rainier, MD
    Did you replace the entire line or just add on to what was already there?
    Its pretty lame that none of the writeups mention needing a longer vacuum line!
    Derr...
    boy412
    ~Eric
    Feb 19 2007
    Charleston, SC
    replace the whole line....should be more than a few dollars (if that!)
    -Sami-
    Apr 09 2007
    2002 A4 1.8T
    Atlanta
    i added with a plastic fitting to connect old/new line. I was lucky we had some vac. line and fitting in the garage.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I didn't have to add a longer vac hose to my DV when installing the DSMIC. You might want to look at the vac hoses and may see about rerouting the lines since the position of the DV has changed. There should be plenty of length in the hose to hook the DV back up.
    USP CLUB MEMBER #34
    Jul 15 2007
    Mount Rainier, MD
    Either way I route the vac line, its still farther away from the DV than it was before. Not sure how yours fit...but its interesting that none of the kits mention needing a longer line. I'm stumped.
    Unfortunately I can't drive the car to go get a longer line. I am not blessed with extra parts (appropriate for the task at hand) floating around my garage!
    boy412
    ~Eric
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    I think I got a longer vacuum tube with an extension tee looking.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | JBOM 100 Cell downpipe | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Mar 29 2005
    Acura MDX
    New England
    Quote Originally Posted by boy412 View Post
    boy412
    weird, mine was completely plug and play.
    i do believe the kit came with a longer line as I the old DV/boost reserve tank sitting in my garage has a vac line attached to it. My guess is that your kit is probably just short one tube? Sorry, it's been 3 years since I installed mine so can't be of more help.
    '12 Golf .:R /
    Jul 15 2007
    Mount Rainier, MD
    I ended up extending the line with some fuel line and a coupler. Done!
    None of the writeups I've seen mention extending the vacuum line. I'd call that a vital piece of information!
    One more note on my install. I found that by removing the pipe fitting at the top of the intercooler (four torx screws, T30?) it made mounting of the intercooler a LOT easier.
    Working with factory parts was a real treat. Everything fit just liek it should (except the short vacuum line of course).
    Cheers,
    boy412
    ~Eric
