Results 1 to 3 of 3
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Front sway bar question.
    So if you didn't see my thread yesterday, I installed my Stasis SS set up. Well when i put it all back together, I forgot to tighten down the front passenger side sway bar bolt all the way and it is no longer there. I'm really happy I had one of those "Oh shit" moments as I was falling asleep last night or else I would have never realized.
    The question is, does anyone have a part number for that bolt?
    Thanks in advanced.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: Front sway bar question.
    Ouch, but good thing you realized.
    Bump for good luck.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Dec 06 2007
    should be the same one as for the rear:
    N10127706
    off RS4 sway bar bracket bolt, should be the same!
    -Kirk
    BetaAlphaTau Member #58
