Car was sold
More pictures: http://www.flickr.com/gp/58298496@N00/100Mpa
The car is 6-speed manual and has 100,010 miles on it. It is in an excellent condition. I have all the service records. Here is the detail:
1.Power upgrades include: GIAC chip, piggie, and supersprint exhaust.
2. Other upgrades: RS4 clutch, Tanoga short shifter, Autospeed DTS, and Koni coilover, APR snub and N710.
3. Appearance upgrade: 18" BBS RA with fairly new set of tires (Goodyear).
Also comes with the car: 17" stock wheels (Avus) with fairly new set of tires.
4. Maintenance history:
a. Two of the most recent services were: all front CV boots (a month ago) and new set of tires (January).
b. July 2007, clutch was replaced with RS4 clutch.
c. November 2006, 80k service - include: brake fluid flush, pollen filter, spark plugs.
d. June 2006, PCV vacum cracked. It was replaced. Basically, my brake was gone. Found the solution in the forum. Dealer confirmed it and replaced PCV.
e. May 2006, after coolant pump was replaced. The car was loosing coolant.
f. January 2006, GIAC chipped - 75k. And install DTS.
g. October 2005, temperature sensor was replaced. Found the solution from the forum. Dealer confirmed it.
h. August 2005, timing belt was replaced - 69,972 miles. Included: tensioner, idler, water pump, coolant, thermostat, serpentine belt. Also at the same time Snub mount was replaced to APR snub and install 710N bypass valve. These two were cheaper when done at the same time and highly recommended if car is going to be chipped.
i. June 2005, front CV boots were replaced.
