Results 1 to 7 of 7
    Registered Member Two Rings jaketone's Avatar
    May 26 2008
    ABC
    Check Engine Light Too hot outside?
    So here in Sacramento it has been 100-107 degrees lately. 2 days ago, when it was 107, my check engine light turned on.
    I drove around for 2-3 miles and then parked it in the garage for 3 hours after which I got back in and drove around the block. By then it was about 99 degrees and my check engine light turned off.
    Is it just coincidence that the light turned on during the heat and off when it had cooled down? Has anyone else ever seen this happen and is there something else I should be looking into?
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Check Engine Light Too hot outside?
    You might have become heatsoaked. You have a FMIC?
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Last time I checked heatsoak didn't turn on my CEL....
    Senior Member Two Rings sinful7's Avatar
    Nov 19 2006
    1994 Schwinn
    Yeh, mine does the same thing, but I have a 3.0. Haven't figured the durn thing out yet, but it goes away on its own! If the light is still on tomorrow, I'll drive over to CSK and have them OBDII scan it.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    If you don't have a vag go down to autozone and have them pull the code, it's free, and will tell you what you want to know.
    -Kris
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Much hotter here, no CEL for me
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    115 degrees all week last week and today. no cel.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
