Results 1 to 16 of 16
    Active Member Two Rings cdc's Avatar
    Jan 04 2008
    Menifee, CA
    Boost problem. Already done a leak test
    I have been getting a CEL code for P1557 Charge Pressure Control: Positive Deviation but it has not been activating the CEL light on the Cluster.
    I have used AWE's instructions on how to do a boost leak test as I have been hearing what sounds like a rushing of air escaping from somewhere when I accelerate from a stop hard, which I thought would be a boost leak. But its not the test did not show any leaks.
    AWE's instructions says it will only find leaks before the throttle body not after. Is there anything I can do to check for leaks after the throttle body?
    I have also read it could be a problem with the N75 valve. Is there anything I can do to check it? But I don't have a VAG to do logs.
    Any help would be much appreciated.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Boost problem. Already done a leak test
    Quote Originally Posted by cdc View Post
    I have also read it could be a problem with the N75 valve. Is there anything I can do to check it? But I don't have a VAG do logs.
    Boost leak is highly suspected. What mods on your car? Chipped? Boost gauge?
    Jan 04 2008
    Menifee, CA
    Car is completely stock and unfortunately don't have a boost gauge.
    Also I forgot to add my drivers side valve cover gasket is leaking, i'm not sure if that would affect anything with boost.
    Jan 04 2008
    Menifee, CA
    anyone?
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Well, I am pretty sure positive deviation means the car is boosting more than expected. If that's correct then search for overboosting. It is usually caused by a bad n75 valve or in more extreme cases, a torn vacuum line to the waste gate.
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Check your Diverter/By Pass Valves, also might be your N75. Also what psi did you pressure test to? If you have a stock throttle body boot, def. check and re check that.
    Dec 06 2007
    Calgary, AB, Canada
    Try a known good N75 valve and also pressure test the hoses going to the N75 (the one on the driver's side of the valve).
    Jan 04 2008
    Menifee, CA
    Ok thanks guys. I pressure tested to 15 psi and could not hear any leaks, i will try and pressure test the N75 lines over the weekend. But if they hold pressure it looks like the N75 valve is shot.
    Should i test all the n75 lines or just the drivers side?
    Dec 06 2007
    Calgary, AB, Canada
    Just the driver's side...
    Jan 04 2008
    Menifee, CA
    I pressure tested the drivers side hose today and it seems to hold pressure, so it looks like I will have to replace the N75 valve.
    Does anyone know where the cheapest place is to get one?
    Veteran Member Four Rings Mantis's Avatar
    Aug 04 2007
    Check with Avalon in Denver, ask for Brian. def would suspect that you are overboosting due to bad N75. A boost gauge is a fantastic investment, if you dont want to clutter the interior with the gauge consider EFU 4U, using your drivers information center to show you vital car info like boost.
    I don't think I care anymore
    Dec 06 2007
    Calgary, AB, Canada
    I can get you one for a good price, PM me if you want.
    Aug 04 2007
    sorry Jordan, didn't thinkk to recommend you
    The Jerbel can get you one quick and cheap, lol
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    I seem to be having similar problems, but no codes yet. when I first drive the car and boost it, it makes that rushing air sound with a little whine to it. and boosts to 15psi instead of 19psi. then I shift and its in limp mode. the sound is comming from the drivers side of the motor. no boost leaks
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Dec 06 2007
    Calgary, AB, Canada
    Test your DV's.
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    I had that problem when I was over boosting. I have a mbc and I turned it down and it ran much better.
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
