Results 1 to 13 of 13
Thread: Runs at Fontana
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Runs at Fontana
    Well I took the car to the track for a few test runs so I could see how the new catch can setup worked, also to see how the car felt with the kevlar doors and battery relocated to the trunk. Have to say it really sucks hitting the track in 100 deg temps and 4000+ ft adjusted altitude at a track that is around 1400 ft elevation, damn I should have just drove to sac.
    Well I was only able to run 2 runs since this was a Summit Racing bracket event and I entered the sportsman class which is a 12.0 or slower class, did this because I know I would get the boot anyway if I ran the car at 100%.
    First run I bogged hard enough to only get a 1.942 60 ft, then ended up not getting into 3rd gear, put it in 5th and then was able to get back into 3rd to finish up the run with a 12.9 at 106 mph. LOL, damn that sucked. But the good news is that there was zero oil spit out of new catch can which is one of the reasons I went to the track to check.
    Second run, still bogged off the line for a 1.799 60 ft but was able to run the whole track without a problem. That run gave me a 11.046 at 133.61 mph with a 7.316 at 105.72 in the 1/8th. In all a good day even though the conditions really sucked to the point that nearly everyone was sitting in their cars between runs with the AC going including myself.
    Would have tried for a better run but I was already running faster then the class I entered and plus I was waiting to get the boot for running faster then 11.5, so I just packed up and left the track.
    BTW while going thru tech I noticed that they now have a digital scale, so after tech I put it on and the weight of the car is 2818 lbs without me in it and with about 5-7 gallons of fuel in the tank. With me in it the scale said around 2975-2980 lbs.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    Re: Runs at Fontana
    when was the last time you actually ran the car all out ?
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Runs at Fontana
    whats that correct to at sea level mike?
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: Runs at Fontana
    let me know when you are gonna go up north to run next mike. try to pick a cooler weekend, though.
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Runs at Fontana
    You're welcome to stay at my house when you go up to Sac
    Jul 07 2004
    socal
    Re: Runs at Fontana
    Quote Originally Posted by Devious27t View Post
    Well I was told Sac was 66 degs around 9:30am when it was already 100 degs here in Fontana.
    Quote Originally Posted by pacman View Post
    I try to run the car hard every time I hit the track, but I really didn't want to break something on the launch when I was trying to test some changes I had made to the car. I ran the car hard at SAC last year when I ran the 10.69, 10.8's.
    I was more then pleased with the 11.04 at 133+ seeing that the conditions were right around equal to what I saw at LACR when the car ran high 11's at mid to high 120's. That was the same setup that ran 10.69 at 135 at Sac so I should see a good drop in my time if I ever get the chance at running the car in a good condition near sea level.
    Mar 02 2004
    Orange County
    Re: Runs at Fontana
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Jul 07 2004
    socal
    Re: Runs at Fontana
    Yeah, but then I had other things going on this weekend so there was no way I could make that long trip to SAC right now. I know greg is going to be back home in July so maybe we can make a trip up there at that point, I also need to see when Dan/Jason might be hitting Sac.
    Mar 02 2004
    Orange County
    Re: Runs at Fontana
    we just need to get a truck and the beast is ready to roll. not my beast of course.
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Jul 07 2004
    socal
    Re: Runs at Fontana
    Cool. I still have some more stuff I need to do on my car, just waiting for Justin to tell me when he has time to help.
    Nov 06 2006
    garage ornaments
    southeastern pa
    Re: Runs at Fontana
    put a cage in that thing, so you dont have to worry about getting kicked out every time you run, haha
    -Nic
    My Car
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    Re: Runs at Fontana
    good stuff for such crappy conditions
    --beejohn
    2001 A4 1.8TQMS
    Jul 07 2004
    socal
    Re: Runs at Fontana
    Hope to do that soon. I haven't yet because I need to have the money first, going with a chromoly cage which is not cheap and I dont want to add more weight to the car then I need too.
