Results 1 to 8 of 8
    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    Location of vehicle speed sensor wire and reverse signal wire
    Hey,
    Wondering where these two particular wires are located. I installed my AVIC D3, and it works fine, but I would still like to hook these wires up to provide all of this information to the unit. It will be much more accurate.
    Are they located under the drivers side kick panel? If so, which harness, and which wire would help.
    Edit: Found this:
    http://tech.bentleypublishers.com/th...ssageID=335740
    Thanks guys, much appreciated.
    -nasty
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Location of vehicle speed sensor wire and reverse signal wire
    use directechs.com has every wire for every car...its what we use in best buys install bay.
    Oct 31 2006
    none of the links on that site work..
    forum, directwire.. everything just reloads the home page. I tried to register but your email address has to be in their system.
    2007 911 Turbo 6MT
    Nov 13 2007
    B5 S4 Avant
    Boston
    hmm...hang on. best buys username is c842bby and pword is 567 if i remember correctly haha. (havent worked there in awhile)
    edit: scratch that,that password doesnt work anymore...ill get it,give me time haha.
    Q7, Q7, F-type manual
    look on the back of your current radio. the pin marked "gala" is the speed wire. as far as a reverse wire, i didnt even bother when i installed my navi.
    Feb 21 2008
    Cleveland
    Reverse wire is only used to turn on the back up camera, if you do not have one then there is no need to hook it up. If you still need the VSS I have access to direct techs at work and will be able to look it up for you if needed.
    -Roman
    Oct 31 2006
    Still need to know a VSS wire location.
    I will hold off on the reverse wire.
    2007 911 Turbo 6MT
    Oct 31 2006
    I'm gonna try the blue and white wire by the driver's kick panel. This seems to be the VSS in every other audi model..
    Edit: Worked.
    Thanks guys.
    2007 911 Turbo 6MT
