Results 1 to 6 of 6
    Mar 15 2008
    buffalo
    Question About Temperamental Car
    Ok guys, i did a search and got a million results, none which seem to fully cover my problem. Heres what happening, starting about a week ago, my ECON button comes on and stays on every once and a while. It seems to be triggered by the rain, but it could just be coincidence. From what i read, its sounds like its a leak in my a/c line, compressor is shot, or im out of freon. But im not convinced about those things because the problem is sporadic. When it works, it works great! I tested it by running it on low at full blast for my entire drive home 45min, cold as ice. But then it rained that nice and the next day, back to ECON. So any thoughts?
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: Question About Temperamental Car
    I'm no expert, but could it be that the humidity is affecting the switch on the A/C compressor?
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Mar 15 2008
    buffalo
    You think it would help any if i did a recharge with the generic kit?
    http://www.audiworld.com/tech/misc34.shtml
    Senior Member Two Rings Joesturbo's Avatar
    Mar 28 2007
    Lewisville, NC
    Quote Originally Posted by zoidberg View Post
    If your AC is cold at any point - you do not need to recharge the system. I think the previous mention of switch atthe compresssor or and other area's in the engine bay which might be getting moisture in them.
    Another area could be problems with the dash control panel. Do you have a vag-com or someone close by who can run a diagnostic check? That might be the best place to start.
    2010 A5, 2010 A3 SP, A4 Avant 1.8T 2004, Corrado G60 + 93 VR6, GTi 1.8T + VR6, 65mpg T-diesel Caddy, Jetta VR6
    Mar 15 2008
    buffalo
    For future reference, it was the high pressure switch!
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Then recharging it could have caused a nasty problem, like an explosion of refrigerant all over the place.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
