Results 1 to 17 of 17
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Question for ppl w/D.I.Y suspension install.
    Hey guys, those who did their own suspension install, i need a little help for the front's i'm putting in.
    I can't seem to get the control links off the hub. What did you guys do? Pry it out with a fork?
    I'm sorta stuck as my rear's are installed, and i don't have the fronts in!!! =(
    Thanks
    Dec 27 2005
    New Orleans
    Re: Question for ppl w/D.I.Y suspension install.
    Im surprised that you are stuck on the fronts but are done with your rears! It was the other way around for me. The rear was a biatch to install, but the front I can do it by myself in like 20 mins. I don't remember all the steps off the top of my head, but I have it saved on a microsoft word file and a pdf..if you are interested pm your email and I will send it.
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    PM SENT! :)
    I spent 5hrs on the rears, yes it was a pita, but i got it done.
    Then i spent 3hrs on the front, and i gave up, coz i couldnt get the control links out!
    I guess i didn't have the right tools.
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    If you're stuck with the pinch bolt then there's a few ways to get it out. Air chisel, BFH, you can take the nut off and try to turn it out from the head.........but,
    what I did, was take off the nut and insert a bunch of washers onto the end of the bolt. Screw the nut on so the washers are sandwiched between the hub carrier and the nut. Take a dremel or some kind of cutting wheel and cut the bolt through one of the slot on the hub carrier. Twist the nut, and the head part of the bolt. It will snap the bolt and you can twist it out that way. Took 15 min.
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    not sure if this will help you specifically, but here is the best DIY suspension install guide on AZ: http://www.audizine.com/forum/showthread.php?t=114492
    also checkout www.a4mods.com for another great DIY guide
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Quote Originally Posted by nsmith12 View Post
    Yes i followed that guide,... the fronts on the b6 vs b7 are a little different....
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Quote Originally Posted by hoganalley View Post
    Hmm, sounds interesting, but i still don't quite understand...
    Registered Member One Ring RedSline's Avatar
    Mar 16 2008
    Sydney
    In this how to cut and paste the bits your having trouble with back into thread
    http://www.a4mods.com/index.php?page...coilovers.html
    Did this same mod on a B7 two weekends ago.
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Have you taken the pinch bolt completely out? If you don't there's no way it's coming apart.
    Sometimes things can get bound up- try disconnecting the sway bar.
    Not sure what you mean about B6 and B7 being different. I've done both and they're identical.
    "Obsessed" is a word that the lazy use to describe the committed.
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Quote Originally Posted by RedSline View Post
    Thanks, this make much more sense,... what i was trying to do was disconnect ALL the control links from the HUB end,...
    Mar 16 2008
    Sydney
    Now that's sorted....
    Post up some pictures.
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Be patient,... i will attempt to finish the fronts tonight. Bought some prybars yesterday,.. hopefully all goes well!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by hoking View Post
    WRONG... they are the exact same... I dont touch those control arms that pinch bolt is never happy
    - Clint
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    you have to take the bolt out first thing or else you're never going to get it off of there. if you do that first before anything else its a cinch
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    what exactly are you trying to pry???
    i followed this diy exactly and you dont need to pry a single thing on the front, its actually quite straight forward. im having trouble understanding where youre having trouble.
    remove the steering link and the control arms and everything seems to slide out pretty easily
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    Quote Originally Posted by Kerschera4 View Post
    well i was trying to pry that control arm link out,.. its quite stubborn,.. yes i finally got this done,... total hrs spent for full install 9hrs!! almost gave up, but is satisfying to finally have completed it...
    pics to come,.. oh ya
    but shit am i pissed that i forgot to adjust the rebound on these koni's as they can only be done while off the car!!! OMG
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    oh man, i woudl be pissed.....time to take them off...but alteast this time you know what issues you'll run into and how to resolve them
