Results 1 to 4 of 4
Thread: FWD brake help.
    Jun 25 2007
    McHenry Co, IL
    FWD brake help.
    Just got some brembo brakes from MJM Autohaus, the fronts went on nice and quick, but I've run into a bit of a snag on the rears. The ABS sensor on the rotor isnt included in the brembo set. (see red arrow)
    http://s300.photobucket.com/albums/n...t=101_0498.jpg
    Is the part pressed on and should be on the brembos or is there a way to remove it? I tried beating on it with no progress. Any help would be appreciated.
    '98 A4 Avant 2.8
    Jun 25 2007
    McHenry Co, IL
    Re: FWD brake help.
    couldnt get the image link to work so i just added the link
    '98 A4 Avant 2.8
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: FWD brake help.
    The rotor is removeable.
    You'll need to lever it off gently, going round evenly to get it off square.
    It then simply presses onto your new disc.
    Lay it on square, place a block of wood on it, then gently tap it home.
    Jun 25 2007
    McHenry Co, IL
    Re: FWD brake help.
    Still no luck removing them, anyone know were to get a pair?
    '98 A4 Avant 2.8
