Results 1 to 7 of 7
    May 20 2008
    Salem, Oregon
    Weird Request, need used stock front brake pads
    I have a B6 A4 USP with B6 S4 front brakes. They are missing the anti rattle springs and have hawk pads. I just read this DIY so I was wondering if anyone still had some used stock pads kicking around that I could buy to get the back part off to do this? Need to fix the rattle, it drives me crazy! I just ordered the OEM springs so I just need these to fix the problem.
    http://forums.audiworld.com/s4b6/msgs/410400.phtml
    Thanks so much,
    Jeff
    Dec 05 2006
    So. Cal.
    Re: Weird Request, need used stock front brake pads
    just to let you know. I had a B6 S4 and my brake system was totally stock and they rattled.
    May 20 2008
    Salem, Oregon
    Thanks for the heads up. I still would like to have all the correct parts accounted for and installed.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Have you tried your dealership? You could get lucky and they have some laying around or could keep an eye out for you.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    May 20 2008
    Salem, Oregon
    Good tip, I will try that if all else fails.
    May 20 2008
    Salem, Oregon
    Still looking... Please help.
    Senior Member Two Rings jaykato's Avatar
    May 25 2007
    2009 Mercedes c63, 2001.5 Audi S4 Avant
    NH
    Rizzag, I am in the same boat. Been running my pads without the springs since they fell off the same day I put the pads in. I am going to try the dealer, if not, yell at Hawk for making the pads with the wrong spring retainer.
    2005.5 S4 Avant Moro Blue.
    GIAC 93, Milltek catless downpipes, Labree catback exhaust, K&N, Bilstein PSS9, 18X8 BBS Diamond Black RE, 35% tint.
