Results 1 to 13 of 13
    Registered Member One Ring brandonp's Avatar
    May 28 2008
    CA
    APR Chip boost cycles..
    I just got an APR chip, and when I gas it at around 2k rpm, the boost builds decently quick to 16psi, and hold there until about 4500/5000 rpm, then it slides down to 10psi all the way to redline.
    Is this normal? Or should I be getting 16 all the way to redline?
    With stock it held the 7psi till redline.
    Dec 05 2007
    CA LA
    Re: APR Chip boost cycles..
    its working normaly. the ko3 can't hold 16 till redline.
    May 28 2008
    CA
    You mean it CAN'T hold 16 till redline?
    Dec 05 2007
    CA LA
    lol ya.
    Veteran Member Three Rings BrokeDown[20V]'s Avatar
    Sep 06 2007
    It doesnt hold because thats the way the wastegate is set-up. I have herd of kids fiddling with the wategate to keep it closed longer, though I dont support the idea on a Ko3.
    Original.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    sounds like my k03's wastegate actuator is too tight then.
    I get boost creap or overboost past 100mph.
    shifting into 3rd it hits 21psi and about 90mph i'm at 17psi and continues to climb
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Sep 06 2007
    ^ and you have APR Software? Im Flashed APR (01 A4) and I spike/hold 17/18 and I have around 9psi before redline. And I have no boost leaks/issues. (knock on wood).
    Which IIRC is a perfectly working software.
    Original.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Same for me. 2001 APR flashed peaks 16 psi and holds no more than 10 till redline. boooo
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Three Rings jankaroni's Avatar
    Mar 01 2007
    Emerson/NJ/USA
    im happy to hear this doesnt only happen to me...i was getting sick of looking for boost leaks and was sure i had got them all.....apparently this is normal operation for a k03S as well
    Jan 11 2007
    texas
    I have a neuspeed .8 bar supposedly. in 5th at 2000-3500 it'll hold 11psi no prob, then it starts creaping up in the higher end of the power band.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Sep 06 2007
    Quote Originally Posted by audinutt View Post
    -richard
    Sorry If im thick headed, but how are you hitting 21psi on a neuspeed .8 bar chip?
    The boost should not creap up like you are explaing, Sounds like your wastegate is not working properly.
    Original.
    Jan 11 2007
    texas
    I know wastegate must be wayyyyy to tight.
    no cel light though.
    I don't really do it very often with gas prices being so high.
    Actually at 300 miles on this tank and have over 1/3 tank left.
    I got a used k03s without an actuator and left the old one where the stop nut was adjusted since i couldn't find anything definitive on how to set it up.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jan 11 2007
    texas
    I'll make a video and upload it. been waiting to get into boost for a while.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
