Results 1 to 33 of 33
Thread: Rough Idle???
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Rough Idle???
    My 2004 A4 1.8t Quattro idles rough. I cannot tell if there is a vacuum leak or what, but it bugs the hell out of me. Without going to the dealership, is there any ways for me to diagnose the problem and possibly fix it? Any ideas?
    Thanks a lot everyone!
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    Re: Rough Idle???
    Do you have a CEL? If so, you can go to AutoZone and they'll give you the codes (and clear them) for free.
    If you do not have a CEL, check:
    1. Check Valves (for a boost leak)
    2. Ignition Coils
    3. Spark Plugs
    The issue may be something else, but I'll bet that it is either a bad check valve or an ignition coil going bad. Make sure to check the check valve immediately behind the engine.
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Jun 21 2008
    Re: Rough Idle???
    Thanks for your reply. No CEL. I can check the spark plugs just fine, but I am not too sure about the other two.
    Where are the valves I should check and how do I check them? What do I need to look for?
    Where are the ignition coils and how do I check them? What do I need to look for?
    Thanks a whole lot, and I apologize for all the questions?
    Senior Member Three Rings Stockton's Avatar
    Mar 04 2008
    2004 A4 Quattro 1.8t 6spd
    Palm Beach Co, FL
    Re: Rough Idle???
    I'm in the same boat. Mine's almost unnoticeable but I notice it and I just know it's not gunna get better on it's own.
    Jun 21 2008
    Re: Rough Idle???
    Just out of curiosity, how do you think it is just going to fix itself? LOL!
    Apr 09 2007
    Cary%2C%20NC
    Re: Rough Idle???
    In regards to the ignition coils, check the following DYI. Bad ignition coils give a very rough idle, loss of power, and a CEL.
    In regards to check valves, check the following thread to see some examples of check valves that are worn out. The particular check valve that I was talking about in my previous post is located in the red circle (see the photograph below - credit to ActiveMonkey for the original photograph). I once had a rough idle with no CEL that was a result of the above mentioned check valve having been damaged in half. The car was fine at speed, but it was rough at idle.
    If I were you, I would first check all of the check valves and then proceed to see if your ignition coils are going out. One of my ignition coils went out on me at approximately 62,000 miles, but the car became really rough (at speed and at idle) in a matter of seconds and it immediately produced a CEL. I hope this helps and keep us updated.
    Registered Member Two Rings kyran A4's Avatar
    Feb 25 2008
    04 Quattro A4 1.8T
    Moorpark
    Re: Rough Idle???
    When I blew a coil in my engine the thing was just straight rough. Rough at all times, it went into limp mode. I couldnt go over like 3,000 rpms. We had all of them replaced and that was at like 46,000 miles. If it were a blown coil pack you wouldnt just be idling rough, as far as my knowledge goes .
    -2004 silver A4 Quattro 1.8T-
    Debadged | RPM 502 18'' Hypersilver | Dunlop Sportmaxx tires | APR K04 | Audi TT 225 injectors | Magnaflow Exhaust | APR Software | ATP downpipe
    Future:
    Euro Code FMIC
    Tein H Springs
    Jun 21 2008
    Re: Rough Idle???
    Thanks yo! So I have a feeling it is not a coil pack, because it isn't that rough. Just when I am stopped. When I place it in neutral, it idles like a dream. So this makes me think drivetrain? What do you think?
    I really know nothing about this as of yet, but the more I learn the better off we all are ;) Thanks a lot and sorry about all the ?????
    Jun 21 2008
    Re: Rough Idle???
    It doesn't idle rough ever, just slight-moderate while stopped.
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Re: Rough Idle???
    I am having the same problem with my car except its only when im starting my car
    Anyone have any suggestions?
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Re: Rough Idle???
    Quote Originally Posted by kyran A4 View Post
    I 've had CPs go and the car would feel ok as long as I didn't go over 3500 or so. Then it would misfire like crazy. As long as I was gentle with the car, I could still drive it. I wouldn't recommend it though.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Walnut Creek, Ca
    Re: Rough Idle???
    Without a smoke tester or vag com to check MVBs, I'd suggest wiggling check valves with the engine at idle. Check vacuum lines and hoses for tears/cracks. Tell tale signs are oil/dirt patches or hissing noises. Check for faults even though you don't have a CEL on, could be something stored. Without something solid to go by all these potential fixes are guesses.
    - JoJo
    Mar 04 2008
    Palm Beach Co, FL
    Re: Rough Idle???
    Quote Originally Posted by 04b6sport View Post
    No, I didn't think it was gunna fix itself. I was saying that I don't want to just ignore it cause it's a car, it won't fix itself I'm sure it will only get worse and turn into a bigger problem if not addressed.
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Re: Rough Idle???
    Depending on what you mean by "rough" idle, could be your snub mount. I had a good steady RPM (1000 at cold start, shifting quickly to a steady 800) but lots of cabin vibration. My idle got better after I reseated my snub. It's still not perfect but for instance my steering wheel doesn't shake anymore.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Jun 21 2008
    Re: Rough Idle???
    Okay, so the car runs great at any RPM. It idles rough when I am stopped and it is in DRIVE. When it is in neutral it feels fine. That's why it makes me think DRIVETRAIN. What do you guys think?
    Do you have any suggestions on manuals I can acquire to locate all vacuum lines. Under the hood is very difficult to see things, even with all the plastic covers removed. It was easy to find all vacuum lines in my Celica, but this is a different story. If I could find all the vacuum lines, I'd be okay, but I can't.
    Also, I do here a hissing underneath the passenger side, rear door. That makes me think fuel pump. What do you guys think about that too?
    Thanks everyone, you are all awesome!
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Re: Rough Idle???
    I've got the same problem. I replaced the vacuum hoses, and coil packs already..still idling roughly when in gear at a stop. Haven't looked into the check valves yet and snub mount..how about you? have u checked the check valves and replaced snub mount yet? Let me know if it's made a difference. I've been having this problem since I got the car..I've looked at postings pertaining to this topic but no direct solution yet...others say they're made that way?!?!
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Feb 14 2008
    xxxx
    Re: Rough Idle???
    The fact that it's worse in gear fits with my (wild-assed) snub mount theory. You could try just reseating yours for now and see if you notice any improvement at all. Check the instructions on the APR site - it's not that hard to do.
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    Re: Rough Idle???
    I think everyone here needs to define what they mean by rough idle. Do you feel actual vibrations, or is that the RPM's are erratic or bouncing. It sounds like there are two different problems being discussed in this thread.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: Rough Idle???
    I think alot of tip owners have this. Chalk me up for having the same exact issue.
    2004 1.8TQ Tip / 47000 miles
    Jun 12 2008
    Warminster, PA
    Re: Rough Idle???
    Quote Originally Posted by skeeball View Post
    In Drive = slight vibration within cabin. No hesitation in RPMs
    In Neutral or park = no vibration / normal
    At speed = normal
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Rough Idle???
    Quote Originally Posted by 02silverb6 View Post
    Idk if this applies to you but I had the same problem after installing my 004 BOV. I had very ruff irratic idle on cold start ups like my BOV was open slightly. (it would sometimes die if you didnt tap the gas.) After a few sec it would go away and be fine. All I had to do to fix it though was put in a stiffer spring, all it good now.
    Jan 09 2008
    California
    Re: Rough Idle???
    Quote Originally Posted by demea View Post
    At speed = normal
    Exactly.
    Sep 20 2006
    Baltimore
    Re: Rough Idle???
    If the car is vibrating, I would check your snub mount for cracks/chunks missing. If you haven't replaced it yet, it would be a good idea to do so at this point anyway. The 1.8T installation is a piece of cake.
    Apr 09 2007
    Cary%2C%20NC
    Re: Rough Idle???
    On the topic of check valves...
    The purpose of a check valve is to allow air flow in a single direction. They're located through out the engine bay (1.8T engine) with the most obvious one being above the air box on the left hand side. Below are poor quality, yet effective, photographs comparing a brand new (and functional) check valve to one that looks like it's deteriorating (but is still functional).
    To check the functionality of a particular check valve, first remove it from the hose - this will more than likely require you to remove the clamps that are securing it. Blow into the check valve - checking both openings. Air should flow in one direction only. Using the above photos as an example, the arrow on the check valve indicates the direction in which the air should be able to flow in.
    The above photos prove a good point. One can not determine the functionality of a particular check valve from simple visual inspection unless it is clearly broken in half. This was the case for me when I started having issues with a boost leak coming from the check valve directly behind the engine - the valve was broken in half between the gray and black pieces. The check valve that looks like it is deteriorating came from above the air box. From just looking at the engine bay, the check valve behind the engine looked fine until I actually went to remove it.
    I hope the above helps those of you still contemplating whether a boost leak is occurring due to a nonfunctional check valve is causing an issue.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Rough Idle???
    A bad snub will only cause a clunk under accel or decel, unless its misadjusted. To me it sounds like you motor mounts are collapsed. Put of the under belly pan and look at the mounts for a reddish fluid.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    Re: Rough Idle???
    Check the hose off the diverter valve... this was the source of my rough idel...
    Jan 09 2008
    California
    Re: Rough Idle???
    Quote Originally Posted by A4Shizl View Post
    Where is that exactly?? Anyone have pix??
    Jun 21 2008
    Re: Rough Idle???
    Quote Originally Posted by jonsaudi View Post
    Ditto!
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: Rough Idle???
    if you haven't replaced all of your braided lines; it is time.
    trust me.
    same goes for check valve(s). my check valve crumbled and got sucked into the $96 (160 at dealer) N80 purge valve.
    talk about a pisser.
    hard starts (esp after refueling)
    mushy brakes
    in general the 4 cylinder is pretty bad for idle with a snub mount and worn out engine mounts :)
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Aug 26 2005
    Re: Rough Idle???
    Yes, fuel pump. Replace the fuel filter asap. '03s has a recall on fuel pumps, check if that is needed still by your VIN, at the dealership.
    The "rough" idle you describe in Drive, is a normal aspect of an Auto trans. But regardless, the vibration can be reduced or practically eliminated by careful adjustment of the front torque reaction snubber mounting. The adjustment must be performed in D, with the engine idling.
    The mounting pocket bolted to the body, is loosened, and positioned so that the vibration is minimized, then bolts tightened before shifting out of D to Park/Neutral. The car needs to be on ramps, while a helper in the drivers seat holds the brakes applied during adjustment of the mount. The car must be fully warmed up before starting this task also. Minimum vibration in D can be further optimized by increasing or decreasing the idle speed a little bit, +/- 10, or 20 rpm can make a big difference. My '03, idles in D at about 830 rpm, with almost no noticeable vibration. When shifted to Neutral, there is no vibration at all, the only way to know that the engine is running (with the radio volume turned up,)is to look at the tach.
    Acceptable results depends on the condition of the main engine and trans mounts as mentioned already. The main mounts must be OK for sure.
    Jun 21 2008
    Re: Rough Idle???
    Awesome, thanks a lot! I will reset my snub mount later this weekend and let you know how it goes. I can't thank you all enough!
    Jan 08 2009
    California
    Re: Rough Idle???
    Hey 04b6sport, did you get a resolution on this issue. I am experiencing the same thing.
    Many thanks.
    Jan 08 2009
    California
    Re: Rough Idle???
    Finally got the issue resolved. It was a dirty intake valve that needed a little cleaning.
