Results 1 to 9 of 9
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    who can analyze plugs???
    i decided to change my plugs today. i followed the writeup on a4mods when i chose the plug. went w/ the ngk bkr6e since i'm in pa... now i changed them really just because i have put more than 30k on the car since i got it and never touched them. and at 101k miles on the car now, figured i'd give them a change since i'm also apr 1+. made sure the new plugs were gapped @.032". and when i pulled the old plugs, they are some autolite platinum something and the gaps were as follows....
    cyl: 1.. .045
    2.. .044
    3.. .045
    4.. .047
    here are the pics of the plugs starting w/ cyl 1 and ending w/ 4... and the last pic is the plugs from left to right, 1-4..
    can anyone tell anything by looking at them other than the obvious.. they arent in the car anymore...
    Dec 06 2007
    Re: who can analyze plugs???
    it's doesn't have good spark, it looks like the wick part that ignites has worn!
    -Kirk
    BetaAlphaTau Member #58
    Jan 16 2007
    Wetzlar
    not bad looking. they all should look the same but they don't.
    install new plugs gapped to factory spec and re-inspect after 5k miles.
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    You can read them with this: http://www.centuryperformance.com/sp...g-spg-192.html
    However, like a2gtinut said, I'd just try new ones in (With correct gap) and see what you get.
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Feb 07 2008
    just the a4
    northeast pa
    i already got new plugs put in.... just wondering if anyone could tell anything from what came out.. runnin rich, lean, detonation, etc....the gap on the old plugs was bigger than what is spec'd. keep in mind, motor is almost to 101k miles... the old plugs have at least 30k on them
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    i can tell you this, get rid of that autolite crap, a b5er i know had an electrode fall out and destroy his enire motor with those crap jobs.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    They look fine, good color, but they look to have some fuel additive stuck to them. #3 looks lean but it will on all our cars. That cyl. gets the most air and the ECU can't adjust individual cyl. A/F.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by festerfm View Post
    cyl: 1.. .045
    2.. .044
    3.. .045
    4.. .047
    Old spark plug's gap is always like that. Their gap always gets bigger.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by dirtybrd View Post
    couldnt have said it better
    - Clint
