Results 1 to 3 of 3
    Veteran Member Four Rings Sablea4's Avatar
    2018 Suburban, Husqvarna riding mower :P
    Charlotte, NC
    i have an issue i need help with. coolant related
    so, for a while i have been having problems with my car. ill explain what happened in some detail..
    1st...i am leaking coolant from here. its a slow leak but it is constant. i have to refill the reservoir every now and then. is there an o-ring or something or do i need a new pipe?
    2nd...it has not done it in a while but i have had the car turn its self off and didnt want to start back up after about 30-45 minutes of medium to hard driving. this happened a couple of times on the trip home as well. all on the same day. it almost felt like i had blown off an intercooler hose because every time i got on the throttle it would hesitate and try to stall out. and not one single check engine light the whole time.
    ....after this i did an oil change and changed the plugs and have not had a problem like that since.
    3rd...it also seems that the coolant system might have a bubble of air in it but i dont know for sure.
    it has been running fine but i just want to find out whats up before i drive to NJ for waterfest.
    so...any ideas? maybe my thermostat? do i need to flush the system? any help would be appreciated.
    Current: 2017 Audi Q7 Premium Plus. Carrara White with Nougat Brown interior. APR Stage 2, RocEuro intake, BMC filter
    Sold: 2005 Audi A4 Ultrasport Avant red with manual transmission USP CLUB MEMBER #6
    Sold: 2004 VW R32 Deep Blue Pearl
    Sold: 2010 VW CC Shadow Blue Metallic manual transmission
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: i have an issue i need help with. coolant related
    That is the bleeder valve and it is a very easy DIY repair the OEM part number is WHT 000 316 and you get a new plug and seal.
    Cost at the dealership is about $2.50
    Should be covered under warranty.
    Charlotte, NC
    is that causing all my problems?
