Results 1 to 6 of 6
    May 22 2008
    Santa Maria
    HELP!!! Headlight error code on dash....
    I replaced my two DRL bulbs with two LED bulbs. I was expecting to get an error code for those, but now I have an error code saying left and right main beam headlight.... I'm confused. Can anyone shed some light on this....? Oh, and yes, the headlights and DRLs do work.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: HELP!!! Headlight error code on dash....
    so put the old DRL back in and see if you get the same error code!
    The usual things!!
    Resistor Install
    May 22 2008
    Santa Maria
    I would, but they were a b!^(h to get out because of my intake. However, just as strangely as it appeared, it disappeared.
    May 22 2008
    Santa Maria
    and then it came back......
    May 22 2008
    Santa Maria
    Looks like it's totally random.... I'm lost.
    Feb 16 2008
    Oakdale, MN
    put the old ones back in. then you will see if it is those lights or not. if it isn't then bring it to your dealer.
    The usual things!!
    Resistor Install
