Results 1 to 14 of 14
Thread: 06 A4 Grill
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    06 A4 Grill
    Ok new guy here with a question, tried to search with no avail... If someone can help me answer this it'd be appreciated.
    I've seen different grills on the "new front end" (2005.5+ models) with and without the square license plate plastic part.
    Let me show you with pictures... WITH the plastic square...
    WITHOUT the square...
    Is what i'm seeing a different grill that only the s4's have or what? I'd like to have the grill without the square for my '06 2.0T. Can someone lead me in the right direction? Thank you!
    Senior Member Two Rings Polskidebesciak's Avatar
    Nov 06 2007
    Old Bridge, New Jersey
    Re: 06 A4 Grill
    you neeed a filler plate, it will not be necessary to change the whole grill
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    Re: 06 A4 Grill
    thanks for the reply. that's why i couldn't find anything on it, because i was just searching 'grill'.
    non s-line fillers out there?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: 06 A4 Grill
    i have one:
    The usual things!!
    Resistor Install
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    Re: 06 A4 Grill
    ^ address please, I'm coming over to steal it.
    ygpm
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    Re: 06 A4 Grill
    you can buy them at audi dealerships or online. online may be cheaper not exactly sure
    Registered Member Two Rings
    Jan 25 2008
    Charlotte
    Re: 06 A4 Grill
    Maybe its just me, but I actually like the look of the square grill more...especially on black. But I've noticed my area usually has the no square grill, so I think it depends on whether your area requires a front license plate or not, for which grill is predominately sold.
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    Re: 06 A4 Grill
    i have a satin black filler
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: 06 A4 Grill
    its the euro filler vs the american filler
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: 06 A4 Grill
    Quote Originally Posted by a4dc89 View Post
    Wrong, the Euro filler is below.
    Feb 16 2008
    Oakdale, MN
    Re: 06 A4 Grill
    Quote Originally Posted by gaede View Post
    ygpm
    HAHA I'm in Minnesota. Make sure you get one that fits your grill, S-line and non-sline or different and wont work with each other
    The usual things!!
    Resistor Install
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    Re: 06 A4 Grill
    thanks for the help everyone
    May 14 2008
    South FLA
    Re: 06 A4 Grill
    Unrelated but, do they make an aftermarket grill without the plate in the middle?
    Just all mesh?
