Results 1 to 6 of 6
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    I just cleaned the throttle body and can't get the car to idle
    there was a lot of gunk in there and i cleaned it out
    played with the idle rod didn't do anything along with throttle body adaption
    any other suggestions
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: I just cleaned the throttle body and can't get the car to idle
    there might be a little build up of the cleaner spray, just run it and see if it clears up
    Oct 28 2006
    i'll drive it around and see how things go - the idle right now is at 1 and a tad bit higher.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    do a few WOT runs to clear it out
    Established Member Two Rings esee135's Avatar
    Jun 21 2008
    I had the same thing, it had a surging idle, and eventually settles out if you load the alternator (heated seats, lights, fogs, fan on high), but if you stab the throttle it goes back into a rhythmic surge, really annoying. The only way I got it fixed was to get VAG-Com and do a Throttle Body Adjustment calibration.
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Just thought I would throw it out there for future searchers.
    Make sure you used the proper cleaner. MAF cleaner is NOT the same as TB cleaner which is diff. from Carb cleaner.
    They should ONLY be used on their specified part. Failing to do so will destroy MAF/ TB sensors.
    Trust me
