Results 1 to 11 of 11
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    APR stage II chip
    i searched! ok!? but i cant get a solid answer.
    I got the 'APR stage I' flash a few months back, and the APR dealer that installed it said that whenever I decide to go stage II with a cat back exhaust he would upgrade/flash my ecu for free to the APR stage II software. Now my question is, what exactly does the APR stage II flash consist of?
    I read that it disables the secondary O2 sensors (for piggies). what else does it do?
    thanks in advance
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    Re: APR stage II chip
    Im sure someone will correct me if Im wrong, but I pretty sure disabling the CEL from coming on is all that it does.
    b5 s4
    Jun 14 2007
    2000 S4
    Connecticut
    it doesnt "disable the CEL" it just doesnt read the rear o2's. if you were to fully disable this cars CEL it would be like driving down the road with a bag over your head, i bet they used long life bulbs in that bitch!
    Jun 02 2008
    2000 S4
    Tell me about it.. I drove the car for 6 months without a working CEL light. didn't realize it wasn't working until recently. So I opened the cluster the other day and found a rubber plug covering the CEL light. I got so mad. Damn that previous owner, he was a russian mechanic and seemed pretty honest about the car.
    So i vag'd the car, and the only DTC was for a faulty MAF, cleaned the shit out of it and cleared the code. CEL's gone
    .....anyone else knows what the APR stage II software flash does? I'm only doing a catback for now, would I see any benefit?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Jurjen View Post
    That's stage II + code, for the downpipes/testpipes. It ignores the secondary O2 readings.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Quote Originally Posted by mholme View Post
    +1
    If you are not doing anything with your downpipes at this time. I see no benefit whatsoever.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Quote Originally Posted by Jayco88 View Post
    thats mad shaddy man.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    I have the stg 2+ software and as stated above it just does not read the cel. There is no gains to be had by the chip.
    Also apr will flash it on there for free, or they did for me.
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    yes the 2+ file is for deleted cats. you must also delete your primaries with the 2+ file or it will over stress the turbos. i went from 2 to 2+ without deleting my primary cats and popped a perfectly good driverside k03
    Jun 02 2008
    2000 S4
    Quote Originally Posted by ThirdStrike View Post
    good to know. So I must first install downpipes/piggies then get stage 2+ software that ignores the rear oxygen sensors.. thanks guys, I have been enlightened.
    Jan 29 2007
    08 S4 00 S4
    MD
    How did it over stress the turbos? I would think if anything would over stress the turbos it would be the pre-cats since they sit like an inch away from the exhaust end of the turbos. I'm just curious as to how a software code that ignores secondary readings from O2 sensors could cause any more stress than just a "normal" chip. I'm running APR 93 with piggies and exhaust, so like I said, just curious about your experience
