Results 1 to 2 of 2
    Nov 07 2006
    Bay Area
    2.8 giac question
    I was wondering if a 2001 30valve (auto) chipped giac ecu, would be compatable with a 2000 30 vavle (manual)?i dont think it will work because of different drivetrains, but i would like to be confirmed.
    thanks in advance,
    peter
    Nov 19 2005
    WA
    Re: 2.8 giac question
    Quote Originally Posted by b5buddy408 View Post
    thanks in advance,
    peter
    As long as the ECU code is the same, and I think it is because it should be the same engine code, then it will work. The car with the manual transmission, which is the one I'm assuming is going to be getting the chipped ECU, will throw a DTC for no communication to the TCU. All that needs to be done is to recode the ECU to a manual transmission. This can be done with a Vag-Com.
    2017 Platinum Gray Metallic Golf Alltrack SEL
