Results 1 to 14 of 14
    Senior Member Two Rings nitelyfe's Avatar
    May 14 2007
    Do we need to warm up our cars?
    I did a search and didn't find anything specifically saying yes or no to this. Does it matter if we do or not? Does it make a difference if you're chipped? I know my A4 seems happier if I let it sit after I start it for the first time in several hours. Seems to like to wait for 2-3 minutes or for the initial 1250 or so rmps to settle down to 800 or so.
    Anyone know the official word?
    2003 Dolphin Gray 1.8TQ Sport
    Mods:
    K&N air filter, Hyperboost DV, Revo ECU tuned, USP front bumper, Bremu bolt down coilpacks, NGK Laser Platinum plugs, ESC Snub Nose engine mount, 18" TSW Kyalami hyper black wheels, Dual XDVD8625 in-dash video, Cobra XRS 9300 (hardwired), Ceramic Formula 1 "auto film" (tint)
    Veteran Member Three Rings favianjanitra's Avatar
    Aug 05 2005
    A6 3.0T Quattro S-Line & VW Tiguan 1.4 TSI R-Line
    Balikpapan
    Re: Do we need to warm up our cars?
    i always wait till the rpm drops to 800 every cold start up..takes about 1 minute plus
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    You are in the bay area, no you don't. Idling and "warming" your car not only kills gas mileage it can also, on the long run damage your emissions and you engine. Read your manual, it will tell you of such things.
    Most of the emission equipment, do not start working until the car is hot, that's why you want a warm car when you smog it. The map for the ecu is a little richer, while the car is cold and leans out as it warms up.
    Registered Member Three Rings P3RryaudiA4's Avatar
    Oct 15 2007
    2000 Audi A4 quattro
    Brocktron Ma
    u start the car up its in open loop, so u run rich until the car starts reading the o2 sensor, wait a min for the idle to drop and ur car is in closed loop, and ur good to go,
    bye
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by favianjanitra View Post
    The ECU idles the car up in order to warm up the car faster. This happens with any ECU car, it is like the "choke" on older carb cars. When the normal temp is reached, the ECU sets the idle to the normal (800). But you don't need to wait for it while idling, as this can be damaging to the components of the car. You should reach the optimal operating temp with about 1-5 mins of driving, but you should go easy on the car until is reached that point, since the oil is still not as viscous.
    Oct 15 2007
    Brocktron Ma
    what components could be damaged, i dont really understand, could u explain a lil more plz ? thxs
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    The manual says you don't need to unless it's very cold out. It says to just start the car and start driving.
    *This means drive it nicely until it warms up, don't just start it up and start ripping on it, BTW.
    -Darrick
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    You shouldnt, if possible, get into full boost until your engine is fully warmed up. That will increase your turbo's life :)))
    I usually wait till my rpms drop to 800. If it's been outside just like for 2-3 hrs, i give it about 5-10 seconds.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    May 14 2007
    Quote Originally Posted by 04QuattroTurbo View Post
    You are not the first person I've heard preach this and it does make sense (first I've seen on audizine though). I'm gonna take your advice. I'm interested to see what it does to my gpm.
    On a side note... DAMN IT'S HOT IN THE BAY TODAY! Fairfield has got to be 100+ right now.
    Mods:
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    When I start mine from a cold start the rpms bounce around from about 600 to 1000 for the first 10-30 secs and especially if i put it in drive right away. So....I usually let mine warm up because it sounds terrible when I first start it up.
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    May 14 2007
    Quote Originally Posted by Capt. Obvious View Post
    Yeah... I've seen it. I'm actually more interested in my car's point of view (mods and all) and even more interested in a if it applies to a even more heavily modded a4.
    Mods:
    May 14 2007
    Quote Originally Posted by Firefighter637 View Post
    I'm pretty sure you change it's "warming" behavior if you switch it out of park.
    Mods:
    Sep 02 2005
    Montreal
    Except in very cold winter weather, you can go as soon as you start, but as a general rule, accelerate slowly and don't rev it past 3500rpm till the water temp gauge points straight up.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Well what I always do when I first fire up the car in the morning is let the rpm drop till 800 or 900 then drive off. During the first 8 minutes you want to drive as normal and gently without getting to boost. These first 8 minutes is the period where the engine oil slowly increases to its optimal temperature. You can check it via vagcom block 130 I think.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
