Results 1 to 16 of 16
    Veteran Member Three Rings cloudpicker's Avatar
    Feb 14 2004
    Past Bay Area-- Now--Hong Kong
    Intercooler for the 2.7t that will direct fit in?
    Hi Guys,
    In the market of some intercoolers with complete piping and accesories. Is there any FMIC kit out there that requires NO bumper cutting with easy fitments?
    I am open to side mount and front mount. I want to cool down my water temp as much as possible, therefore i wouldn't find a smaller core..
    Cheers
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Re: Intercooler for the 2.7t that will direct fit in?
    I think if u search a bit youll see that a mitsubishi core from an eclipse is direct fit.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by cloudpicker View Post
    Hi Guys,
    Cheers
    If your goal is to keep the water temp. down as much as possible, then you definetly does not want to go with a FMIC. Blocking air flow to the radiator is the major weakness of any FMIC. I would look into larger capacity or more efficent radiator instead.
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by GURUMAN View Post
    you may need a few zip ties on the lower side grilles .
    OP, on the S4 we have air to air intercoolers so the water temp isnt going to be changed unless like Tifosi said you end up blocking it with the FMIC. you are the first to want to lower water temps not intake airrrrrrrrrr temps!
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    Isn't the ASP FMIC a direct fit? But you have to cough up like 2k for it.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    true but it comes with everything you will ever need, including an EFK, perfect piping, clamps, bolts, a greatly designed core, and the kitchen sink. idk if it's worth it though. i'd like to see some comparison graphs between it and the ebay fmic core w/ piping
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Apr 27 2004
    Pacific NW
    IIRC, the ASP FMIC does require modifications to make it fit. It is not a direct drop in unit. Plus, the OP has an RS4, I think the radiator support is also different when compared to the S4s.
    Feb 14 2004
    Yea, after all, i think i am considering going back to the oem Rs4 smic for the better water temp as the FMIC is really blocking the air flow..
    Feb 14 2004
    Any idea the ER SMIC will fit my car? Since my car is RHD, will there be any problems?
    Mar 20 2008
    Italy
    So are you selling your DUH???
    I'm going to pick up mine this evening, a brand new COMPLETE (oil/sterring rad, electric fan etc.) one.
    Don't tell me it will be a bad choice...... :(
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by andream88 View Post
    If your regional weather gets pretty hot and humid, then you may very well experience some abnormally high water tempertures, especially if you are sitting in traffic. Remember, these cars were never designed to have FMIC in the first place, so unless you plan on doing a series of modification, FMIC may not be the most ideal setup for a DD.
    Apr 27 2004
    Pacific NW
    Best thing to do is to contact Mike at WMS ( http://wicked-motorsports.net/ ), he has done tons of ERs and was actually involved in the creation of these SMICs. However, since the B5-RS4 never were sold here in the US, let along a RHD car, he may not know either. But if anyone can help you, it would be him.
    Mar 20 2008
    Italy
    I will eliminate the bellypan and try to bring more air to the engine.
    Thanks
    RS4 B5
    Feb 14 2004
    Let's say if i want to upgrade the radiator too what choices do i have?
    Mar 20 2008
    Italy
    Another smaller radiator in parallel.......?!?
    RS4 B5
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    the 20' x 20' 21784124781275123hp supra IC is a direct fit.
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
