Results 1 to 15 of 15
    Registered Member Two Rings audiRSallroad's Avatar
    Jun 19 2008
    2001 allroad
    RS6 Honeycomb grill on Allroad?
    I'm new to Audizine so Im not sure if this is the place to ask this but does anyone know if the RS4 or RS6 honeycomb grill would fit on a 2001 allroad? or if there are any quality aftermarket alternative that retains the audi rings?
    I dont know if its just me but i think the grill on the allroad just doesnt match the honeycomb lower down on the bumper. any help would be appreciated
    heres some pics for reference
    Veteran Member Three Rings Alpinevelo's Avatar
    Dec 28 2006
    06 VW Jetta I5 daily driver bone stock 4 now
    Fountain Hills, AZ
    Re: RS6 Honeycomb grill on Allroad?
    I am almost 100% sure it will not, however many people buy one of each and do a cut and paste job that can turn quite nicely with the help of a good dremmel and a glue gun. There are a few posts you can find also under the A6 forum regarding this I believe I saw one that could help you about 2 months ago. I am eyeing an AR myself and if it happens will definitely do just that. Welcome to the forum by the way, beautiful AR. Mine will go straight from the dealer to the body shop for a bumper and lowers paint job because it will not do much off roading... Also find someone with a Vag com in your area and you can make it go pretty low on them airbags...
    C5 A6 2.7T GIAC software Stage 1, EVOMS DV Valves, Cupra spoiler lip, RS4 OEM 18" Wheels.
    Alex
    Veteran Member Four Rings seank's Avatar
    Nov 14 2006
    here
    They do not swap out, the AR hood is different from the RS6 or any A6 hood for that matter, I was contemplating this for a long time for mine. You can try what was stated above.
    Registered Member Four Rings cerfus's Avatar
    Oct 16 2007
    Germans
    Scottsdale
    this is all you have to do, buy an RS6 honey comb grill and cut it out, and then chop your factory grill out leaving the chrome outside. Then mod your cut out rs6 grill into your AR chrome surroundings. You can use somekind of industrial grade glue or something to hold it in place. I did that for a buddy, looked great on his A6
    ///Mcars
    looking for a sileighty..
    E39 M5 DD full Hamann exhaust h-back/ Hamann CF splitter/ Hamann C Diffuser/K&N intakes/ecu tune more to come.
    Keep your eyes peeled DG, CRFS coming your way!
    Nov 14 2006
    here
    Thumbs down to glue, if you are going to do it, do it right and plastic weld it. Also I don't know why you would do that for someone that had an A6, as I was informed that the RS6 grill would work on A6 hoods.
    Veteran Member Four Rings 4ringAR's Avatar
    Sep 18 2006
    Colorado
    Quote Originally Posted by seank View Post
    some a6 hoods.
    i think there are like 4 different hoods for the C5, but 2 basic shapes.
    type 1a is the initial a6 hood.
    type 1b looks like the type 1a hood, but for some reason the hood latches are different and thus the grille needs some modification to work.
    type 2a is the facelifted normal a6 hood(narrow body).
    type 2b is the facelifted a6 for all v8 models, and is slightly different to type 2a, but with some work they are interchangable.
    type1:
    type 2:
    2001 Audi ur-allroad, Frankenturbo'd, 6-Speed Convert: BUILD THREAD
    "Forget Tibet, free the left lane."
    Oct 16 2007
    Germans
    Scottsdale
    Thats because a 1999 A6 has a different front end (that includes the gril) than a 2003 RS6..
    ///Mcars
    Sep 18 2006
    Colorado
    instead of using the expanded mesh from home depot, check this out:
    http://cgi.ebay.co.uk/KUNSTSTOFF-WAB...742.m153.l1262
    Registered Member Two Rings Allroad Mat's Avatar
    Dec 26 2007
    Allroad 2001
    Hong Kong
    Just send you a PM as I have my ABT Front Hood Grill available if you are interested.. Also, my car s also metalic silver whereby, no pain job for you is needed... Just Plug and Play...
    Allroad Lover........
    Nov 14 2006
    here
    Here is the DIY RS6 I did this weekend to mine. I'm waiting on the spare grill to show up that I order, then I will actually cut the factory bars out and just run the diamond mesh.
    Sep 18 2006
    Colorado
    looks good sean. how did you attach it?
    Nov 14 2006
    here
    The 2 pieces are on with some black zipties right now. They will be fixed in a more permanent way when I cut the other grill apart.
    Jun 19 2008
    2001 allroad
    you just ziptied the two pieces to the original grill right? and would it be difficult to fill in above and below the rings? other wise it looks great
    Nov 14 2006
    here
    Yes as of right now the pieces are just zip tied to the factory grill bars. As for putting mesh below and above the rings, the space is really limited so yes I think it would be difficult to attempt to put anything there and it would just end up being single pieces you wouldn't really see a diamond anyway, therefore, I didn't see it necessary to put anything there as the factory grill really doesn't have anything there either.
    Nov 19 2008
    Florida
    Sweet job SeanK ,where did you get the diamond mesh and what size diamonds?
