Results 1 to 40 of 46
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    It seems like everyone gets better gas mileage than me
    I drive about 60% streets and 40% highway.
    Whenever I'm looking through threads I see people getting like 330+ miles a tank. At most I'll get 240-250. One time I got 295 when I was going about 80% highway. What's the deal?
    My engine mods are only Neuspeed chip, neuspeed exhaust+test pipe, and I'm pretty sure that's it.
    BTW, I drive pretty normal too. Maybe one WOT for each tank.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: It seems like everyone gets better gas mileage than me
    Do you do a lot of short trips with a cold car?
    -Kris
    Aug 11 2007
    California
    I wouldn't say a cold car but I do a lot of short trips.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    im all short trips. 90% city. i get 240 260 miles per tank.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Oct 22 2005
    Reppin the Mitten.
    short trips, and ur HUGE 20's really don't help. I'm guessing you were referring to my thread? :P Downsize to some 18's man :P. Can't really help you about the short trip part.
    Aug 11 2007
    California
    Well I guess I'll just have to drive my car longer! Oh well...
    And yeah Vinny, your thread just made me WTF my life. My 20s aren't THAT big.
    Buncha motorcycles
    Memphis, TN
    probably related to your driving style
    but short trips do hurt a lot.. also depending on your total miles, it could be o2 sensors affecting it as well
    APR Stage 2/AWE Intake
    Dec 06 2007
    Stay Out Of Boost And It'll Get Better!
    -Kirk
    BetaAlphaTau Member #58
    Aug 11 2007
    California
    Damn 02 sensors.
    I want to hear from some more Neuspeed Chippers. It obviously makes you run rich since I can shoot flames. So Neuspeeders, speak up!
    Oct 09 2007
    E46 M3
    PA
    ...crickets
    -Kris
    Buncha motorcycles
    Memphis, TN
    lol... why neuspeed chip? get APR or GIAC.. ill bet your mileage will improve
    Aug 11 2007
    California
    The Neuspeed HQ is about 5-7 miles from my house. Figured I'd give it a try and I've just been too lazy to switch to GIAC.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I get about 300miles/tank. I drive mostly in the suburbs/// 30% hwy.
    Maybe thats because of your wheels???
    And aslo, maybe i just started driving slower, BUT, after i erased the history of throttle body, my shifts are much smoother and it seems like im getting better gas mileage... Or it has something to do with hot wheather.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Aug 11 2007
    California
    Hot weather sucks. It's 107 where I live.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I dont really like the AC, so i dont use that a lot. And yeah, o2 sensor is a common gas mileage problem.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I got 188 on my last tank.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 27 2005
    North Wales, PA
    using ac and short trips where your motor never gets up to temp KILL gas mileage. Especially if you have to stop at a couple lights. I could get 300 per tank all city driving with the ac on. 350 miles with the ac off. same streets to and from work. I roll windows down unless its over 90*
    Oct 22 2005
    Reppin the Mitten.
    Remember the summer blend gas is better on gas mileage then the winter as well. And yes 20's are huge comparo to my miniscule 18's :P
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Some observations from my own experiences:
    1. BOV will eat gas, probably because of all that unmetered air, not getting back into the intake track. The car tends to run richer than with a DV setup.
    2. Free flowing air filters, 'seem' to eat more gas. Stock airbox gives me the best mpg.
    3. mufflers make a huge difference. on the same note, running cat-less will most likely eat gas, probably because the exhaust gases from the manifold pass with much less restriction through the turbo as compared to a setup using a Cat.
    4. Weight. I have a sound system in my car, a heavy ass one at that. I dropped 2-3 MPG depending on driving conditions just because of the system.
    5. Rims do make a difference. On 17s, I had the best MPG. 19s are no good on gas.
    6. FMIC has decreased my MPG. Even though it was designed to has as little pressure drop as possible, I did notice a slight drop after I installed.
    7. Sludge?
    So here are some solutions that i have followed:
    1. i got a foam air filter from JC Whitney. This fit inside stock airbox. MPG improved and I felt more power as compared to stock.
    2. If you can run a HFC, that's a good option because a little of airflow restriction may go a long way to create some backpressure for your engine/turbo. Especially from dead stops, you may n ot notice it, but It seems the engine will overcompensate for the lack of backpressure to car going from a deadstop. If you help it out a litttle with a HFC, you should see an improvement in MPG.
    3. SEAFOAM is your friend. Use it to Clean your injectors and fuel system. Use it in the crankcase (sludge?), and finally in the intake manifold (vacuum track).
    4. Unload your car of unnecessary equipment, junk.
    5. Depending on what body kit you have, you may want to get one with less of a "snow-plow" bottom valence. My Reiger creates massive wind resistance. I noticed this right after I put it on. It creates more Down force, but probably at the expense of creating more drag as well.
    Anyway, that's what comes off the top of my head at the moment.
    Happy Tuning.
    Z out.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by dirtybrd View Post
    LOL, whats the record???
    BTW, my friend installed headers on his e90 330i, according to his computer, he used to get about 19.8mpg, now if he drives normally on a hwy, he gets about 25 mpg... So i would say +1 on a HFC/TestPipe.
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by aaaudiprotein View Post
    On my tank? That's the least I've gotten, it should be about 300 even with a built motor and BAT. I don't pound on it that much. I think when REVO flashed my ECM they put in the wrong file. I'll be shipping it back to them on Monday.
    I'm back bitches!
    Active Member Two Rings AudiDWK's Avatar
    Mar 20 2008
    2005 B6 A4 1.8T
    Cerritos, CA
    Neuspeed flashed, K&N drop in filter, dv, 17" stock wheels - I'm averaging 350-375 miles per tank. That's with probably 65/35 city/highway. The best I've gotten is around 525 mostly highway.
    What I've noticed is that the "miles remaining meter" in the cluster is a bit off. When the meter says you have 0 miles left, you actually have a some gas left in the tank. The gas meter on the right of the cluster is a little misleading as well - when the gauge hits the red empty line, it can actually go a couple more millimeters until actual empty. Furthermore, when the cluster beeps alerting you to refuel, you actually have about 2.4 gallons left in the tank (from the manual) - which will give you around another 50 miles or so.
    Check your manual to confirm all this. Hope this helps.
    Veteran Member Three Rings DGS4's Avatar
    Apr 28 2004
    fast legs
    Quote Originally Posted by Tony@Autobahn View Post
    If it makes you feel better, I drive around the same as you at 60% street 40% highway with the same habits.... Getting roughly about 180 miles to the tank on a good day. All highway on a full tank about 275 miles...
    But honestly, When I had my 1.8T with the same habits as you, was averaging 250ish also. The best ever was 310.
    Who knows.
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by DGS4 View Post
    Who knows.
    Your car is running rich then. You need a new MAF or a 02 sensor.
    I'm back bitches!
    Aug 26 2005
    I believe it is probably due to the test pipe. Without a cat, and the compromised O2 sensor calibration, the fuel mixture is likely richer overall than it would be normally.
    Aug 26 2005
    Why do you prefer to be uncomfortable and instead avoid using the A/C?
    Aug 26 2005
    Remember that a high powered sound system, especially if turned up to an effective volume, loads the engine more due to the power required to drive the alternator that provides the watts used by the system. It's just a higher auxiliary load that requires more fuel to operate. Plus the extra fuel used to haul the extra mass around, as you already mentioned. I bet the higher electrical load is equal to, or more than the weight regarding increased fuel consumption.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    No, when its hot, i turn the ac on, but when its ok, i usually open a sunroof and rear windows. I get sick easy from AC.
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    I fear i've been going too heavy on the gas lately so when I filled up yesterday I reset the trip meter and now we'll see how many miles per tank I get. I never wait to fill up when its on red, I always usually refill with 60-70 miles left. That lasts me a week.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Senior Member Two Rings lfloodt's Avatar
    Feb 18 2008
    Black '05 A4 Avant 3.0Q 6speed
    philly, pa
    i just changed my fuel filter and instantly noticed 1-2 mpg difference on the trip computer. i'm thinking about seafoaming soon too.
    '05 B6 Avant/6 speed/3.0Q / De-cupholdered armrest....
    Dec 06 2007
    something must be wrong like an 02 sensor for us! i've changed my MAF, my fule filter, seafoamed all 3 ways, did my valve cover gasket, and the only thing i have is a small VAC leak i think, but still get only about 19mpg!
    -Kirk
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    ^^^ Spark Plugs???
    Dec 06 2007
    ^^done that 3 times in 5 months tried a ton of them!
    -Kirk
    Veteran Member Four Rings thebikedoctor33's Avatar
    Jul 06 2007
    Bremerton, WA
    i was thinking one day. is it smarter to not fill up. like get only half a tank. that way you car carrying around less gas. haha. idk if it would make a differnce, i meant just the drive to the gas station more often might offset that...
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    your 20" wheels are so heavy I bet each of them is like 35lbs plus tire weight that's like a total of 60lbs at each corner. that kills gas mileage
    do you have your belly pan? if not you need that.
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Dec 06 2007
    ^^stock 17" wheels were 48lbs each when i shipped them!
    -Kirk
    Aug 11 2007
    California
    My 20s weigh 1 pound less than my stockers.
    May 03 2007
    german
    heaven/hell
    47lbs with tires? I don't believe you
    Aug 11 2007
    California
    Well the rim itself weighs I believe 24 pounds? I just remember that it's 1 pound less than the stocks and those are 25-26.
    Aug 11 2007
    California
    20s you say? WHORE TIME!
