Results 1 to 24 of 24
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Quick exhaust question! Fabbing up my own
    i started to do my own exhaust yesterday, just some preliminary welding cutting and measuring. today im going to start taking my old exhaust off and start the new one. my question is, how much do you think it matters where the muffler is placed? right now mine is underneath me, near the middle of the car. what if i were to place the muffler right near the exhaust tips? any difference in sound, or flow charecteristics?
    ThorTechnik.com
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Quick exhaust question! Fabbing up my own
    I do believe it does matter due to the sound resonating within the straight pipe or pipe. I believe it would be louder as well.
    l gotta-- l gotta get
    a form from a scientist.
    Mar 07 2007
    Belmont, MA
    so it would be louder to place the muffler near the end, rather then in the middle of the car?
    ThorTechnik.com
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    yes
    B7 RS4...mmmm.
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    my s had cat back and the muffler was near the tip like 5 or 6 inches from the tip it wasnt unreasonably loud. im doing a custom exhaust as well now that im doing the k04s. are you doing true dual or 3inch. check out aero turbine mufflers they have some crazy technology in it that makes a vortex which gives you negative back pressure once done ill have some videos
    Mar 07 2007
    Belmont, MA
    im doing 3.5" all the way back with a dynatech splitflow muffler. should have it done tomorrow afternoon, will post pics and vids.
    ThorTechnik.com
    Sep 20 2007
    norwich
    Quote Originally Posted by S4evr View Post
    3.5" isnt that a little big? i know 600+ Hp V8's running only 3"
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by b5s4blk View Post
    tell that to bertwerks who had a FOUR inch in his 12.2 second K03 car.....I'm doing a 4 inch on my K04 car....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Feb 26 2008
    Rockford, MI
    there is not such thing as too big when it comes to exhaust....get your facts down
    B7 RS4...mmmm.
    Registered User Three Rings S4M3's Avatar
    Jul 12 2007
    B5 S4,B8 S4, E55 AMG
    Atlanta, GA
    I have some Electric cut outs for sale . If u need any for you setup . let me know :)
    Mar 07 2007
    Belmont, MA
    think of it this way:
    most of the true dual exhaust's use 2.5" tubing. the combined cross sectional area is 9.82", while a single 3.5" has a cross sectional area of 9.62 so infact it is extremely similer to running a dual 2.5" setup, it's just easier, cheaper, and lighter to design a single 3.5"
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by S4M3 View Post
    thanks, but as is it will be plenty loud, and plenty of flow.
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by Blue_S4 View Post
    depends on the application, NA cars need a certain amount of backpressure to produce the maximum amount of power, so too big could infact hurt a NA's performance.
    ThorTechnik.com
    Jul 17 2004
    99% of all true-duals use 2.25'' tubing (ASP, UUC, etc...). So cross sectional area is actually way less than both 3.5'' and dual 2.5''
    And yes, there is no such thing as too big on a turbo car.
    Alex
    2001.5 Nogaro Blue S4, 6-Speed, ARD 2.7T 68mm HTA GT2868 Kit
    Mar 07 2007
    Belmont, MA
    Quote Originally Posted by lil' is 300 View Post
    oh snap didnt know that lol
    ThorTechnik.com
    Registered Member Two Rings THICK S4's Avatar
    May 29 2007
    Boston
    DUDE YOU SHOULD RUN NO EXHAUST AT ALL
    IT WOULD SOUND NUTS LIKE A JET PLANE
    twin GT28's = my S4
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    run a faux exhaust... just put tips on it but leave it at the downpipes. less work... i'm a big advocate of half-assing stuff that's not necessary
    yeah technically you dont need an exhaust at all on a turbo car once past the turbos. in a 4 cylinder honda or v8 mustang, they need exhausts to put a little backpressure on, as not to lose flow characteristics, and in turn, torque (dont want to lose what's already lacking on the honda). but for our cars, the turbos create all the backpressure you'll ever need, so we can just run straight turbos as exhausts. problem with that is Johnny Law and your elderly (or toyota prius schmuck environmentalist) neighbors will complain about it being LOUD, which it is. We only have them to turn that raw sound of God, into heavenly sounds.
    good luck with it, cant wait to hear some clips. always love it when people do a DIY exhaust.
    How much did it cost you in tubing? total hours worked on?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    forgive my ignorance... but why do engines need backpressure? i always thought that backpressure was the enemy because more energy is wasted by pushing the exhaust gases through all the turbos/pipes/cats/mufflers etc.
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Mar 07 2007
    Belmont, MA
    im not sure, but there is some gas property that makes the exhaust gas act like a vacuum in NA cars so if the tubing is the right diameter the gases are almost sucked out, however if the tubing is too large you loose that effect. (something like that) that of course doesn't happen with turbo cars because the exhaust is getting pushed out.
    ThorTechnik.com
    Mar 07 2007
    Belmont, MA
    muffler: Dynatech 76-006352 - $98
    tubing: (4) 45* bends Dynomax 41429 - $30.69 each
    8' 3.5 straight tubing - $30
    exhaust tips: Magnaflow 35125 - $35 each
    grand total comes to $340.76 shipped
    about 4 hours in, should finish tomorrow with another 3-4 hours needed.
    ThorTechnik.com
    Jun 02 2008
    2000 S4
    S4ever let us know how it all turns out.. and if you're able, could you post a sound clip or something?
    you just might inspire me to do the same thing.
    good luck
    Established Member Two Rings 2k1.5blacks4's Avatar
    Jul 02 2007
    2001.5 s4
    Birmingham, Alabama
    I don't run any exhaust after the downpipes and i have them tied up with a coat hanger (lazy need to get exhaust hangers or cut them off after the flex joint) and neither does my brother in his S4. In Alabama there are no emission checks (for now) and I have never had a police man say anything about the noise. There is cab drone especially if you have loose coins or dropped bolts but LOUD PIPES SAVE LIVES. Plus in the south every body and their brother has the exhaust cut off their or its some hunk of junk that never had a exhaust check. People don't really seam as put off by loud vehicles as much down here.
    May 29 2007
    Boston
    S4ever, i saw you in NY the other day, the car sounds like SECKS
    Nice job on the exhaust mod, it sounds like 4 planes
    twin GT28's = my S4
    Mar 07 2007
    Belmont, MA
    funny, i am living in MA right now and was not in ny yesterday..
    exhaust is on, will post pics once i'm home and hopefully i can get a video clip soon!
    ThorTechnik.com
