Results 1 to 7 of 7
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    where is the crankshaft position sensor?
    i searched and couldnt find anything and checked vagcat also. diagram preferred but an explanation will do
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: where is the crankshaft position sensor?
    Quote Originally Posted by volks88 View Post
    bellhousing of the transmission
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by mholme View Post
    Yeap and on the left side ,''driver side'' of your engine. I can see it, now engine is removed for stage3. Look's like a bitch to reach with the engine in place. Is it a common issue on those?
    Established Member Two Rings DAP's Avatar
    Mar 16 2004
    Quote Originally Posted by Reich View Post
    Yeap and on the left side ,''passenger side'' of your engine. I can see it, now engine is removed for stage3. Look's like a bitch to reach with the engine in place. Is it a common issue on those?
    Unless his car is a UK (rhd), I'm pretty sure the crank sensor is on the DRIVER side of the trans bellhousing.
    Oct 14 2007
    Val-Belair
    Quote Originally Posted by DAP View Post
    Your right. I don't know why i wrote it this way. It's still on the left side of your engine and yeah driver side. Any way. is it a comon issue on those? It look's like a hard reach sensor. You can see the sensor harness heat protection close to turbo. That gives you an idea of how hard it is to replace.
    May 06 2007
    it took longer to jack up the car than it did to replace this. still didnt fix my problem tho
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    where can I get a new sensor (other than dealership)?
    I'm thinking mine may be going bad... car starts fine in the mornings after sitting over night, but after it has been driven it takes a couple more turns for it to start up...
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
