Results 1 to 3 of 3
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    quick cam question
    the dealership is closed so I cant call them, but does anyone know:
    are the stock cams in an ATW the same as an AEB?
    TIA
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Re: quick cam question
    I've swapped cams from an AEB into my AWM with no problems. You should be fine.
    "You know you have a bad idea when Ford guys are making fun of you."
    Jan 06 2007
    NH
    k thanks, I was pretty sure the top end was the same and only the ports, throttle body, and management was different.
