Results 1 to 6 of 6
Thread: 45mpg
    Registered Member One Ring 2ürNbRn's Avatar
    Nov 21 2007
    Audi TT
    Boise, Idaho
    45mpg
    Last Monday my check engine light came on, so I popped the hood to take a look.... and look what I found. Since my CEL come on I've noticed considerably better MPG, I found it interesting and thought I'd share.
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    Re: 45mpg
    I'm not familiar with the TT, but is that the hose ripped off of the diverter valve?
    Any ideas how that happened?
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Nov 21 2007
    Audi TT
    Boise, Idaho
    Re: 45mpg
    The hose is dry and brittle from heat exposure over time. It ripped off of the metal object in the foreground, not sure what it's called. The Diverter is in the top of the picture (shinny anodized black 007).
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: 45mpg
    Run lean- will toast your pistons and valves. Fix it.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Oct 21 2006
    2014 Audi S4, 2003 Audi A4 Avant 1.8tqm
    Westminster, CA
    Re: 45mpg
    thats the combi valve, connects to the electric air pump. that valve is also referred to as the EGR valve
    Registered Member Two Rings THICK S4's Avatar
    May 29 2007
    Boston
    Re: 45mpg
    combi valve, you're probably running lean like the guy said 2 posts above me..
    45mpg with cylinders calling for more fuel
    twin GT28's = my S4
