Results 1 to 40 of 71
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Christmas in mid June?! Thank you STaSIS! My rear BBK is here…
    This was at my door when I arrived home this afternoon.
    Aluminium caliper brackets.
    Alcon two piston aluminium calipers.
    Alcon rotors with their aluminium hats. Their size ~ 298mm by 21mm.
    STaSIS even put heat sensitive paint on them so I can see what temperature I will reach on the track.
    Performance Friction race pads, model PFC 01. I ordered two sets of fronts and two sets of rears. I’m waiting on some street compound versions. In the mean time I will continue to use Ferodo 2500s for the street.
    Feb 17 2005
    Sarasota, FL
    Re: Christmas in mid June?! Thank you STaSIS! My rear BBK is here…
    WTF! Why dont they sell those to the public?
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by A4ringedONE8T View Post
    It's a race kit that is used on their cars and is not legal for the road (no emergency/parking brake)... Think I care?
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    interesting
    Some fast things and some slow things
    ~Josh~
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by mtbrider View Post
    interesting
    No I won't be able to use the parking/e-brake. For now I will leave the lever and cables in place in case we come up with a solution and also not to attract too much Police attention (if they ever looked in) LOL.
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    Quote Originally Posted by Jet Jockey View Post
    thats funny, considering the inside of your car looks like a race car anyways
    03 A4 - Sold
    Sep 02 2005
    Montreal
    What alloy are those brackets made from? They look awfully tall and thin.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Here's you a parking brake.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2005
    Sarasota, FL
    I've inquired about one many times. I couldnt careless about the lack of an Ebrake. I live in FL, the biggest hills we have here are made by ants
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    So, why can't you use the parking brake?
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by T0M3K View Post
    The calipers have no mechanical movement aka "parking brake" built into them. You would need to use a Hurst line lock or add an additional ebrake caliper
    Mar 21 2006
    Lakeland, FL.
    It's built into the stock caliper
    I'm back bitches!
    Jun 17 2004
    Montreal, Canada.
    Don't know and I'm not about to second guess them on that design when this kit as been used for a long time on their race cars. It works, it's reliable and that's good enough for me.
    Mar 21 2006
    Lakeland, FL.
    A line lock won't work as it requires power to hold it shut. There are companies that make locks that use pulses of power to run them. Hit the switch once and it closes and again to open it.
    I'm back bitches!
    Sep 02 2005
    Montreal
    Because the aftermarket calipers don't incorporate the parking brake mechanism.
    Sep 02 2005
    Montreal
    I'm asking because I'm about to make my own, so I'd like to know which alloy works best.
    Jun 17 2004
    Montreal, Canada.
    Well I understand your point of view believe me but perhaps STaSIS is worried about legal issues.
    Also another point to remember is that the small master cylinder on the A4 wouldn't work properly with this kit because of the added size of the pistons in the rear calipers.
    That is why I went for a full blown race pedal system (Tilton) so that I could have the proper individual master cylinders to operate the race kit properly.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Those are sweet
    BUT.... I'll stick with brembo rears
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by dirtybrd View Post
    My understanding about line locks is that they are also illegal for road use especially as an e-brake solution because they rely on the same hydraulic lines as the regular brakes.
    As for a separate caliper that is a possibility because some fancy sport cars used them (CGT for one) but here again I believe you need both rear wheels to be equipped with them to stop the car in case of a brake failure.
    Sep 02 2005
    Montreal
    Quote Originally Posted by RLB6 View Post
    Those are sweet
    We can take bets on who's setup "works" better.
    Feb 17 2005
    Sarasota, FL
    The new Brembo 4 wheel setup seems to work pretty damn well, better than my Alcon's I will say
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    I'd take Brembo over Alcon too. Brembo in my opinion has the strongest rotors and the fact that they're the only brake manufacturer that has their own exclusive forge is pretty impressive. Nonetheless, Alcons are great brakes as well, most likely equal in quality. I would simply take Brembo if I were spending that much money.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    I would love to come home and see that on my front door. You lucky mofo! One day...I will have some...brembos of course. :)
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Sep 20 2006
    MD
    I'll be more willing to bet on my setup as it has been specifically designed to work with OEM master cylinder AND not to mention I'm running the M 6-piston caliper setup up front.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    FWIW I own STaSIS/Alcons (370mm front and 298mm rear) and Brembo MS is a much better setup.
    Sep 02 2005
    Montreal
    You'd lose that bet. But it's understandable, considering how much you spent on that beauty queen BBK.
    Feb 17 2005
    Sarasota, FL
    Jet's setup on a typical A4 vs the Brembo 4 wheel kit, Brembo's would win, sorry
    Buncha motorcycles
    Memphis, TN
    i wouldnt complain if i had either kit both are very nice and no doubt provide substantial increases in braking power
    but maybe you guys can see who can piss farther?
    APR Stage 2/AWE Intake
    Sep 02 2005
    Montreal
    That's irrelevant, I'm taking about Jet's setup specifically, which includes all aspects crucial to braking performance, like curb weight, weight distribution and pad material, among others. So, with that in mind, RLB6's setup just looks pretty, that's all. I'm sure Jet will also be able to tweak the brake bias, which is something RLB6 can't do, so he's stuck with the OEM like, front bias, because just like understeer, it's safer for the general public, but it's a compromise when it comes to pure braking performance. Those huge Brembos won't stop the car any quicker than a much smaller, 4 piston in front, 2 in back kind of setup could, with rotors as small as 310mm. Sure he's got lots of fade resistance, but really, on a slushbox equipped car? What's the purpose? Also, four larger pistons are easier to modulate than six or eight tiny ones.
    But hey, if he bought his Brembos for looks only, he couldn't have done better
    Sep 20 2006
    MD
    I hope they don't do random drug screening at your job. That statement right there makes you a prime candidate
    Sorry, you could only BARELY, I mean BARELY do better than what I have..for looks that is
    Sep 20 2006
    MD
    Now, imagine if he had my setup on his ride.
    Sep 02 2005
    Montreal
    I'm self employed, I can go to work being as high as a kite if I wanted to... But I digress. Even a small rotor with a four piston caliper can generate enough braking torque (simple math) to surpass the friction coefficient of your tires, in relation to the mass of the whole car and its weight distribution. And what stops a car? The tires, not the brakes.
    Your BBK is an expensive beauty queen, your rear setup especially. Your car is front heavy so the actual effectiveness of your rear brakes, during weight transfer, becomes so small, the stock single piston caliper, with a sub 300mm rotor is perfectly up to the job of keeping up with the front. That's why Stoptech doesn't even bother with the rear, and Alcon suggests only a better rotor, and only for better heat dissipation, not for more brake torque.
    You should look up piston sizes too. You might have more pistons, but they're smaller.
    Jun 17 2004
    Montreal, Canada.
    Guys I did not want this to be a piss off contest between brake systems.
    However mxrz is basically correct on all counts.
    Also if you have the small OEM B6 A4 master cylinder in your car chances are it won't supply properly all your brake pistons/calipers unless Brembo took that into account which I doubt.
    On the other hand my STaSIS/Alcon set up is properly calibrated with the proper independent master cylinders to work with the proper size pistons in the calipers. It is also a well proven race set up they have been using for years now so again I doubt your Brembo set up will be as good or as efficient as this set up.
    BTW, I could have gone with the Alcon 6 piston set up but even STaSIS says it's overkill for my car and indeed for their race cars. This would also require another set of master cylinders to make the system work properly. The advantage I have is that it can be easily done on my car but not on a stock A4.
    I'm glad you are happy with your Brembo set up and I'm sure it is a good set up especially for street use.
    That's it and that's all... Enough arguing please just enjoy what you have on your cars!
    Just my $0.02.
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    its always nice to come home and see new goodies on your door step!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Veteran Member Three Rings darkstar's Avatar
    Dec 25 2004
    1998 silverado, 1986 c10
    Folsom, CA
    Jet you're my hero!
    Sep 20 2006
    MD
    Just my $0.02.
    Do you honestly believe that shit you're shoveling? I'll leave it at that.
    Sep 20 2006
    MD
    Um, yeah. sure.
    Jun 17 2004
    Montreal, Canada.
    LOL... What ever!
    Sep 02 2005
    Montreal
    Um, yeah. sure.
    For your own good, educate yourself: http://www.stoptech.com/tech_info/te...e_papers.shtml
    Mar 21 2006
    Lakeland, FL.
    Sorry RLB6, but they are both correct. To a certain extent size doesn't matter. Of course a larger rotor with dissipate the heat better and make fade nonexistent but, are you tracking you car? Also you have to factor in the ABS. With ABS, if you car will engage it and your stopping distance is (just throwing a # out there), 200ft. a bigger caliper and rotor will not make it stop shorter but will allow it to do that same 200ft. stop 20 times. Where the stockers will just fade and the distance will start increasing.
    I'm back bitches!
