Results 1 to 3 of 3
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    H&R Spring Part # Difference
    Hey guys,
    Just want to know what the difference in part number is for some H&R Springs
    29368.2 vs 29368.0
    1st one is for 6cyl
    2nd one is for 4cyl
    I'm wondering if it's only the spring rate difference?? Since the minimal difference in part number is the end #.
    I ask because I picked up some springs off a B6 3.0 Quattro, seeing if it will fit on my B7 2.0T Quattro Avant
    Thanks!!!
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Re: H&R Spring Part # Difference
    the issue is the weight of the engine is significantly different. Therefore the ride might in fact be higher, but stiffer. A strange combination. Buy parts meant for your car, it works out better.
    Oct 06 2006
    02' Yamaha R6
    Coquitlam, B.C.
    If its only a weight issue, if gone through the specs,...seems to be only about 100lb difference between the 2 cars... I'll get back to you guys when i have it installed...
    Can't go wrong if it only cost me $100 for the springs/shocks combo =)
    Thanks
