Results 1 to 9 of 9
    Senior Member Two Rings jaykato's Avatar
    May 25 2007
    2009 Mercedes c63, 2001.5 Audi S4 Avant
    NH
    OEM Front Caliper Spring on Hawk HPS Front Pads not fitting
    The front set of my Hawk HPS brake pads have a different connection with the caliper spring, meaning the spring clip doesnt have a slot to fit in. Any ideas?
    2005.5 S4 Avant Moro Blue.
    GIAC 93, Milltek catless downpipes, Labree catback exhaust, K&N, Bilstein PSS9, 18X8 BBS Diamond Black RE, 35% tint.
    Senior Member Two Rings wva s4's Avatar
    Jan 19 2008
    Charleston,WV
    Re: OEM Front Caliper Spring on Hawk HPS Front Pads not fitting
    I will take a look at mine, changed them out for a track day and had no probs., was going to change back this weekend to stock pads.(sounds like a schoole bus) Let you know what I find..
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    I had a hell of a time getting it to fit as well. You just have to bend the tab some.
    Jan 19 2008
    Charleston,WV
    are yours as loud as mine? my 1st 2days with the pads were at the track, and now they are unbearable.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    May 25 2007
    NH
    S4J, thanks a million!!
    May 25 2007
    NH
    wva s4, my pads only squealed once when I was pulling out of my driveway after a rainy night. Other than that, whisper quiet.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    my pads went right in no issues and they don't make noise
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jan 19 2008
    Charleston,WV
    I was afraid the 2 day VIR event was kinda hard on things. Rotors are slightly warped and the thing sounds like a school bus....oh well still a great 2 days !!!!
