Results 1 to 14 of 14
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    Exclamation how to remove seat belts from rear deck lid?
    Does anyone know how I could actually remove the rear deck lid out of the car and be able to take out the seat belt things from the deck lid? I'm recovering it and am kind of stumped.
    Oct 02 2007
    toronto
    Re: how to remove seat belts from rear deck lid?
    Remove the housing for the third brake light. Then do the child belt harnesses (there's three of them) pop off the plastic cap, then unbolt them. Don't forget the third brake light harness. Then I think you just pull, it's been over a month now since I did it - might be one or two more bolts.
    May 28 2007
    Northern Virginia
    right, i got that far... but how do you remove the seat belts that go into that plastic circular thing and down through the deck lid???
    May 28 2007
    Northern Virginia
    Help!!!
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    i;ve always wondered this too.
    The only option that i could come up with was to slit the decklid with a razor blade
    May 28 2007
    Northern Virginia
    not a bad idea... however i'd rather not
    Oct 02 2007
    toronto
    you mean the plastic assemblies? Fiddle with them lol.
    There are a bunch of snap-fit things, you need a flat head screw driver and *CAREFULLY* pry them out. It's not really something I can explain, you need to look at the assembly and look where to press and pry if I'm remembering correctly.
    Oct 02 2007
    toronto
    The seat belts are bolted to the deck lid and just below the seats (remove the rear seat completely) if that's what you mean.
    May 28 2007
    Northern Virginia
    I'll get back at it tomorrow, thanks everyone!!!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    pop up the lower seat (just pull up) and there you can access two 17mm headed bolts that hold your seatbelts in place.
    from underneath the package tray push upwards on the cover (the part you're recovering) and it'll pop up.
    at this point you can see the small clips that hold the seat belt pivots in place. You can turn the plastic bits sideways and slide them through the holes w/o damaging the package tray cover.
    install is reverse. I just did the same w/ mine, and it turned out great. Looks OEM, and it's not all faded like before.
    May 28 2007
    Northern Virginia
    NICE!!! Yep, I'm going for that nice OEM look myself...
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by K04B5 View Post
    Here's a before and a couple after pics. I had some speaker box carpeting that matched the interior about 99%.
    Before (faded, and nasty) Cell phone pic.
    After. Looks amazing in comparison to me.
    Jan 26 2007
    Charleston SC
    what material did you use?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    AudioPipe Speaker box carpet. I found it at The Andersons, in OH. It's like a Meijer, except smaller. They have a lot of cool stuff, and I found that carpet there for $18. It was a sheet of 4'x18'.
    I used a total of ~2ft on this project since it's pretty much the right width on the roll.
