Thread: Rods & Pistons?
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Rods & Pistons?
    Hey can anyone tell me with certainty (sp?) what the pistons can handle as far as HP goes?
    Thank you,
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: Rods & Pistons?
    Wish I knew as well. Everybody here chips there cars, some put larger turbos on and I have still yet to read a thread about stronger internals.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    Re: Rods & Pistons?
    if you search for the mk5 gti/gli the internals are the same for our cars... at least thats what the shop told me that i ordered my rods from...
    07 b7 a4 2.0t stage 3
    Jan 27 2007
    NC
    Re: Rods & Pistons?
    Well im really looking for info on the pistons because if they can hold REALLY WELL up to 500hp that would be great cause that would mean that i only need pistons, I was looking to drop the c/r to 9.2:1CR instead of stock which is 10.5:1CR "More Boost"
    Oh and i just finally pulled the FP and all is AOK! even with 90,000mi on motor!
    P.S. Can anyone donate a 2.0FSI block?
    vizi
    Quote Originally Posted by matttl16 View Post
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Rods & Pistons?
    Check out the 2.0T FSI forum on vwvortex threads like this
    -Kris
