Results 1 to 8 of 8
    May 12 2008
    Bucks County, PA
    Need Help ASAP!!!
    Hi, I have an '02 A4 1.8T Quattro which I'm rebuilding. Now this is the first Audi I've put my hands on and I'm not a pro-mechanic just an aficionado. Anyways, after plugging most of the cables and sensors I have come across a few issues and I was wondering if any of you savvy guys could provide me some info and help in order to solve this issues. The following are the issues I have come across:
    • The Kombi Vave or SAI is broken and I'm replacing it as soon as the dealer gets it. Is this really an essential valve or it does not really come into play?
    • I'm missing something which I have no clue what it is, but it's located between the power steering reservoir and the manifold intake. REFER TO THE PICS .
      I might have taken it off and misplaced it somewhere. I think b/c of this I have a couple of cables just wondering around. Do you think I'm losing power due to this cables not being plugged properly? Does anyone know what's this thing called? Or what's its function?
    I would really appreciate all the help. Thanks.
    Senior Member Two Rings geoshu's Avatar
    Feb 20 2008
    '03 A4 1.8T Quattro
    Vancouver, WA
    Re: Need Help ASAP!!!
    I have an empty space in mine too, thats how it was when I bought it, seems like something is missing. I have a plastic cover over mine though, so it fills the void. I was told that the 3.0 has something there, but the 1.8 shouldn't.
    But a direct picture from the top would be more helpful
    May 12 2008
    Bucks County, PA
    Quote Originally Posted by geoshu View Post
    Thanks for posting. Are you sure that there shouldn't be anything for the 1.8? I mean I have 2 cables that I have no clue what's their function and I'm almost sure that there should be a connection in that empty spot. You right, I should get pics from the top and kind of get a close-up to get a better idea. I'll try to get those pics posted ASAP. Thanks again for the help.
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    I believe that spot is for some sort of vacuum or brake booster that is needed in Automatic cars. Assuming that yours is manual and that is what you are indeed talking about then that space should be empty.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Jan 31 2008
    Grafton, WI
    I have an empty spot there as well, I don't think you should worry about it.
    2005 Infiniti G35 RWD, 6spd Manual, Sport Package
    2002 Audi A4 Quattro, 5 spd. [SOLD]
    Aug 26 2005
    The Combination/SAI valve is only active for a couple of min just after cold start up.
    The "missing" item is a vacuum pump to boost the power brakes on Auto/Tip cars. It's not used on manual trans cars.
    May 12 2008
    Bucks County, PA
    Thanks everyone. All the help has come in handy. I just replaced the SAI Valve and I sure feel a difference I don't know why, but it seems like I'm getting the right pressure now. About the empty spot I'm only left with on cable that needs to get plugged, but I think is one of the side signal lights. I'm going to check tomorrow. Now another issue I just noticed when I changed my front bumper to an aftermarket one that does not have the spot for the washers, neither the fog lights is that my cluster shows a failure signal for both. Is there someway to cancel or erase it? Thanks again guys...
    Aug 26 2005
    Quote Originally Posted by burneo1217 View Post
    Thanks everyone. All the help has come in handy. I just replaced the SA Valve and I sure feel a difference I don't know why, but it seems like I'm getting the right pressure now. About the empty spot I'm only left with on cable that needs to get plugged, but I think is one of the side signal lights. I'm going to check tomorrow. Now another issue I just noticed when I changed my front bumper to an aftermarket one that does not have the spot for the washers, neither the fog lights is that my cluster shows a failure signal for both. Is there someway to cancel or erase it? Thanks again guys...
    To simulate the missing fog lights, you need to determine the highest resistance value in ohms that will result in a circuit load in amps sufficient to satisfy the self check system, and connect a resistor in place of the fog lamp.
