Results 1 to 38 of 38
    Veteran Member Four Rings alen's Avatar
    May 10 2004
    1.8tqms
    ghettlanta
    Brake light and annoying 3 beep chime coming on every few minutes of driving..
    This has become so frustrating.
    So last weekend I replaced my pass side CV booth. In the process I touched one of the ABS sensor boots (no big deal). Put everything back, and voila every time I drive the car, slow down, accelerate, usually between speeds of 0-35mph I will get three beeps (like the gas light one) and brake will flash either a few times or until I shut the car off. This goes off maybe 5-10 times on a 4mile drive from work to home. What gives? Did I inadvertently touch or move something?
    Car is 2k 1.8tq.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Brake light and annoying 3 beep chime coming on every few minutes of driving..
    something is wrong with the abs sensor. check the wires and make sure the sensor is clean.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Veteran Member Three Rings oldblu's Avatar
    Jan 01 2008
    Budd Lake, NJ
    lol I JUST fixed this problem on my car this morning. Top off the brake fluid and let us know what happens. Since you're accelerating, the nose goes up and the brake fluid just misses the sensor. Try it
    --Silver 2000 A4 2.8L V6 Quattro
    S4 Bumper. Borbet Type LS Wheels. M3 Replica Spoiler
    Blue! How come there's no ice
    in my lemonade?
    Senior Member Three Rings kjr7888's Avatar
    Nov 23 2006
    NH
    ^ check your fluid first!
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Quote Originally Posted by oldblu View Post
    You should never add brake fluid. If you are low on brake fluid it must mean its leaking somewhere. I might have missunderstood what you were saying so I am sorry for the missundestanding.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    your ABS control module is shot...pretty soon the lights will stay on all the time
    Oct 28 2006
    Quote Originally Posted by VTAudiA4 View Post
    x2
    May 10 2004
    1.8tqms
    ghettlanta
    Quote Originally Posted by AudiRacerS4 View Post
    I hope you're kidding.
    See this is the thing. A few months ago I put in an aftermarket horn. To mount the relay, I drilled a hole on top of the plastic piece covering ABS relays (near the ABS control module). Well, I drilled into one of the wires, but I was able to solder the wire together (PITA).
    Ever since (maybe 5 months now), I'd get the Brake light and mandatory three-beep every once in a while (maybe once a month). But after replacing the CV booth, it's on every few minutes.
    I think it's time to check if the soldered wire is ok, or if the ABS sensor is dirty, or gawd I hope it's not the ABS module.
    Registered Member Two Rings
    Dec 28 2004
    pennsylvania
    Is it the yellow abs light on solid and the red brake light flashing? If it is, my car is doing the same thing, and from what I've heard that usually means its the ABS module.
    For you it might be something else since you have done repairs on the wire and maybe something with the wheel sensor.
    I tried to find out if the warning lights came on in different ways depending on what the problem was, like just the yellow light solid or blinking or with the red brake light, but I never found any info on that, just that the common problem that everyone has is usually the ABS module. I asked a local independent vw mechanic about it and we were going to check the codes and see if it was a wheel sensor or something else and the more I told him about what it was doing he said thats most likely the module and so I didn't bother getting it checked out.
    It was kinda here and there for awhile, but now as soon as I start the car every time it beeps with the lights, so I do believe its the module, and I haven't got around to sending it out to get repaired yet.
    99.5 a4 1.8tqm
    93 318is
    Veteran Member Three Rings audimuse's Avatar
    Aug 10 2007
    09 MB C63 AMG
    denver, co
    yeah im going to have to agree and say its the abs module. mine did exactly that thing early this spring, and now it is constantly on. the dealership even told me a couple months ago (stupid flasher switch) after they ran my car through diagnostics check that i would need to replace my module soon because it was blown. sure enough it stays on all the time and gets annoying, but look at this way. speaking of which does anyone know if an b5 s4 abs module will work for a b5 a4 2.8?
    May 10 2004
    1.8tqms
    ghettlanta
    I forgot to mention, the light that keeps coming on all the time is the brake light, abs light never comes on.
    this happens all the time now, i could be driving the car in neutral no brakes applied, when the car is stationary, etc.
    i can fix your module.
    contact via email please.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    sorry not to thread jack, i have also been getting a beeping going on when i open my door when my car is on. It only has been happening sometimes though. anyone know what that could mean?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Established Member Two Rings diablooffire03's Avatar
    Jun 21 2008
    N. New jersey
    thread jack again. sometimes my master window switch wont put the front passenger window up. itll put it down though. any ideas?
    05.5 Audi S4
    01 Lexus IS300 Turbo
    08 IS250AWD SOLD
    94 6spd single Supra SOLD
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    alen, is the brake light solid or flashing? If it flashing your fluid is low, just check it and add as needed (the level is on the side of the reservoir). For your window not going up, possibly your window regulator going out.
    Sep 17 2006
    07 cbr600
    my firends car did this and he added a little bit of brake fluid and it went away
    May 10 2004
    1.8tqms
    ghettlanta
    ok, so i checked the brake fluid level and it was within spec. still i added a little more and the light and the chime do not come back as much but still appeared a few times.
    ^ its your abs module. what is so hard to understand about that?
    May 10 2004
    1.8tqms
    ghettlanta
    nothing really. if you read the original post, this started happening RIGHT AFTER i changed my pass side cv booth.
    something like that leads me to believe that I must've touched a sensor or something before i can assume something on a bigger scale.
    then you add these other responses about brake fluid, etc, i'd like to eliminate simple potential sources of issue first.
    or you can just call it denial lol.
    either way, if i scan it with vagcom, will i see any codes (if it's the abs module)?
    if it was a speed sensor issue then you would only get an abs light.
    if you have a defective module you will have a code in the ecu about a communication error. and you will not be able to connect with the abs module.
    Jun 19 2007
    2012 JSW TDI
    Raleigh, NC
    Quote Originally Posted by k0mpresd View Post
    not true. i had a speed sensor go out and the car would beep 3 times, the abs light would light up, and the brake light would blink.
    but that doesnt sound like the issue here, because it never beeped at me more than when the lights frist came on (a few seconds after i started the car)
    my current abs module throws an open circuit left side speed sensor code. it only lights the abs light.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    What is a CV booth? How come I don't have one?
    ΜΟΛΩΝ ΛΑΒΕ
    May 10 2004
    1.8tqms
    ghettlanta
    ^lol.
    Ok, so I scanned the car and no codes from the ABS.
    Also, I'd like to reiterate that only the brake light comes on with the beeps. ABS light does not come on.
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    this happens to me sometimes under hard booosties, add brake fluid every few months and it goes away. I guess im only band aiding the real problem thoughh
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    May 10 2004
    1.8tqms
    ghettlanta
    brake fluid level is good. i added some for good measure, but no good.
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    i have the same problem. brake light comes on and beeps. It started slow but now i cant stand the beeping every few minutes. The brake fluid is fine. is it the module guaranteed?
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Senior Member Two Rings my 1.8t's Avatar
    May 04 2008
    tucson
    could this be due to sensored brake pads that are worn? i have the same issue rite now and i think i need new brake pads. i have sensored pads thats why i ask.
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    WRONG, dude. As your pads wear your fluid will go lower because the piston willbe extended further and further. If you have to fluid every then yes, you have a leak. Otherwise adding fluid about halfway through a brake pad's life is normal.
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Quote Originally Posted by my 1.8t View Post
    If you have sensored pads, the light will come on in the center of your display. The brake light on the right only comes on during low brake fluid and when your e-brake is engaged.
    Jul 01 2008
    Minnesota
    +1 about abs light only with sensor. If you arent getting codes, its power to the abs module, or the abs module thats bad.
    May 04 2008
    tucson
    Quote Originally Posted by lotusgardener View Post
    well my abs light is stuck on and my brake light blinks. i chimes 3 times but only when i first start the car.
    May 10 2004
    1.8tqms
    ghettlanta
    Just to provide an update.. the issue is gone!
    This is what I gathered: A little before the problem surfaced, I drilled a small hole on the plastic cover of the brake connectors and relays to place a bolt that holds my aftermarket horn. As I drilled through I inadvertently cut through one of the wires. I soldered it and all was fine. Then, after a while, the beeping initiated. Abs light never came on. Just blinking brake and beeping.
    It would come on randomly.
    I wanted to revisit my soldering job. Everything was still intact, but the soldering caught some surface oxidation. I cleaned (sanded) it off and taped it well this time, and voila. It never came back.
    I believe with all the other issues where the ABS light blinks it has to do with the control module, as many others have previously stated.
    May 19 2009
    1.8T A4 2002
    I have the same solid red brake light flash along with 3 chimes. What's interesting about this is on my way to work almost every day, the chime happens in the same spot along my route. It's like clockwork.
    02 A4 1.8T
    Jan 18 2012
    Quebec
    Quote Originally Posted by snakes02A4 View Post
    Same thing happened to me this week! It starts beeping within a few blocks every day, 10kms into the drive (6 miles).
    Did you figure this out?
    Established Member Two Rings silvera4q's Avatar
    Dec 20 2007
    2001 Silver A4 1.8T
    Cincinnati, Ohio
    PM Kompresed. He will fox it for you . Fixed mine a few months back and works like a charm now. $50 compared to like $600 most will charge you for a new one. Do it!
    2001 A4 1.8t quattro, Mods:GIAC-X tuned, Short shifter, apr snub, custom CAI ,cat back 2.5" ss exhaust, custom carbon fiber interior parts,VDO Boost and Oil Pressure Gauges, yellow fogs
    Dec 20 2007
    2001 Silver A4 1.8T
    Cincinnati, Ohio
    Quote Originally Posted by MrPinson View Post
    When mine was bad it would come one after a few minutes when it was real cold out. Its you modual. PM Kompresed he fixes them.
    Jan 18 2012
    Quebec
    Went to my mech on the way home and as it turns out, my brake fluid was really low as one of the rear calipers was leaking. So there you go... Looks like the infamous '3 beeps' can be any number of things!
